Replacing NM In Existing Home - Electrical - DIY Chatroom Home Improvement Forum
Old 02-22-2010, 01:24 PM   #1
Rewards Points: 866
Replacing NM in existing home
I have a 15 amp circuit feeding a bathroom and I want to upgrade it to a 20. Can this be done without opening up the sheet rock walls and space between the first story ceiling and second story flooring?
It was wired, when it was code in the early 90's, with #14. I am thinking that I could go from station to station and connect the end of the new 12 to the end of the old 14, and then pull it through BUT PERHAPS FOR STAPLING, assuming the cable is stapled every foot and a half. If it is, and the run isn't too long, is it often possible to just tug on the cable to loosen the staples?
Assuming that can be done, do I have to open up the walls and ceiling to staple the new #12 cable to the framing.
I am trying hard to avoid opening the drywall. The newer paint in this particular room is impossible to match and I would have to repaint the entire room should I have to cut the wall.
Klawman is offline   Reply With Quote
Old 02-22-2010, 01:59 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 23,958
You won't be able to use the old cable as a pull. It just doesn't work with the bends and staples.
Except for holes needed to fish the new cable you don't need to open the walls to staple. Fished cables are permitted to hang free inside the walls.
Old 02-22-2010, 04:28 PM   #3
Electrician
Rewards Points: 910
Why do you want to upgrade it to 20A are you haveing problems with tripping. If you are haveing no issues, follow the good advice that if it isn`t broken then don`t touch it.
darren is offline   Reply With Quote
Old 02-22-2010, 04:31 PM   #4
Rewards Points: 866
Makes sense. Thanks. I have access to a fishing tape. Is it unlikely that the I will be able to fish the new 12 awg cable through the existing holes while leaving the old 14 AWG in place.
Also, how do I figure out where the cable from the panel connect into this circuit? I would think it would be at the fixture/receptacle nearest the panel and I should begin, after shutting off the breaker to that circuit, by taking a look at the cabling connecting with it. If one side is 12 and the other 14, disconnect the 12 and flip the breaker back on. If the entire circuit is out, that is station #1. Of course, if the wire in and out of #1 is 12, I check what I believe is the next nearest station and do the same. continue as such until I find where the circuit drops down to 14 and that is where I have to swap in the 12 AWG. Is this pretty close to being correct?
Old 02-22-2010, 04:42 PM   #5
Rewards Points: 866
Originally Posted by darren View Post
Why do you want to upgrade it to 20A are you haveing problems with tripping. If you are having no issues, follow the good advice that if it isn`t broken then don`t touch it.
As is, the same circuit feeds the sole receptacle for my garage and I am getting into woodworking as a hobby. As is I have a table saw and a miter saw and will soon have a router and drill press. While usually only one power tool is on at a time, a 15 amp line is a bit light even if it makes code.
I agree with you, though, about leaving it alone if it ain't broke. Problem is I understand the reason code now requires a 20 amp circuit for an outlet in a bath because of the decreased fire danger. Is the risk so much more that I should consider the circuit broke? I don't know but am planning what I should do as long as I intend to be adding some other circuits in the garage, (A 240 and probably another 120 for the garage)
Old 02-22-2010, 05:04 PM   #6
New code indicates 20a & feeding the bathroom(s) outlet ONLY
So if you are going to run a new circuit make it a dedicated bathroom circuit
I'd also run another 20a circuit to the garage & leave the 15a in the garage
Hair dryers can use 1500w or more - about 83% of a 15a circuit
There isn't any decreased fire danger
Danger occurs when a circuit is over loaded...extension cords are used that aren't rated for the load...loose connections, old frayed wiring...plus other issues
Old 02-22-2010, 05:25 PM   #7
Retired Moderator
Rewards Points: 7,174
Often an ordinary pull-out ruler is handier than a fish tape inside walls...
Have fun and hello again!
Old 02-22-2010, 05:56 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 946
If you are not having trouble with the bathroom, just add another circuit to the garage.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 02-22-2010, 06:43 PM   #9
Electrician
Rewards Points: 910
I second jbfan, if you add a circuit to the garage you could always cap off the old plug in the garage and then the bathroom will only be on that circuit.
Old 02-22-2010, 07:51 PM   #10
Rewards Points: 866
Thanks all. I think you are all on the money.
I don't think there is any reason not to and good reason to at least run the new 240 in the garage. At the same time, I will add a separate 110 line just for the garage.
As for that pesky bathroom circuit, I may just leave it be until the day I either have problems on it or it makes sense to upgrade the circuit during some remodeling.
Scuba_Dave: You are right about hairdryers. I think my wife's is lower powered, yet it is marked 1875 Watts and 125 Volts. Even with that on high heat and the lights and ceiling fans on the circuit being on, the 15 amp breaker didn't open after three minutes. Not even when I then cranked up the 12" miter saw plugged into that single garage receptacle and then cut a 4X4 fence post to put it under load. I think a couple of you guys, Joed and yourself, may have seen my posting re testing that circuit with a coffee pot, an iron, toaster oven, and the miter saw and it finally opened the breaker. I am rethinking whether that breaker is good.
Hey Oh'Mike. Gotta take care of that new saw. (I sold the old one off of Ebay to a local attorney.) Meanwhile, my crown moulding turned out rather well.
jbfan and darren: Capping off that one outlet so that I don't have to mess with this questionable circuit for the time being is a great idea.
Old 02-22-2010, 09:12 PM   #11
Electrician
Rewards Points: 910
If your bathroom circuit will be by itself, i can almost gurantee you with out doubt you will never have a problem with it. How many devices on the market have a 20A cord plug on it, very few(none that i have seen) so you will probably never draw more then 15A on that circuit.
Old 02-22-2010, 09:43 PM   #12
Rewards Points: 866
Without splitting hairs, I think you are right. (one could plug a hair dryer into one outlet of the duplex and an electric space heater in the other. Some idiot may use a plug in device to give them additional outlets for who know what.)
Old 02-22-2010, 11:06 PM   #13
Super Moderator
joed's Avatar
Not inconceivable that hair dryer and a curling iron are plugged in at the same time.
Old 02-23-2010, 08:10 AM   #14
jbfan's Avatar
Rewards Points: 946
Happens at my house every day!
Old 02-23-2010, 11:14 AM   #15
Rewards Points: 726
Psh, hey when you have as sister that is using a hair straightner and TWO, yes two! hair dryers simultaniously, then you have a probem... *LOL* my sister use to do that and trip the circuit every time and never figure out why when they ran together it happened...
BlueBSH is offline   Reply With Quote
Tags
replace nm
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 53 03-29-2015 08:15 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
History of Lomonaco's Iron Concepts & Home Decor John Lomonaco New Member Introductions 0 11-08-2009 10:39 AM
!!HELP!! Rain leaking between existing home and new addition NJGirl357 Roofing/Siding 4 09-10-2008 05:06 PM
Replacing existing wall with support beam or I beam sourdough Building & Construction 4 08-06-2008 09:42 AM
