Replacing And Moving A Fuse Box With A Breaker Box - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-24-2009, 06:56 PM   #16
Rewards Points: 266
Originally Posted by nightrook View Post
Hey Junkcollector, can I install the ground rods about 12ft away from the box. I have concrete sidewalk and the closest dirt exposed is about 12 feet away.
Yes, the rods can be as close to the building or as far away as necessary.
Just as long as you can keep the wire protected.
junkcollector is offline   Reply With Quote
Old 09-24-2009, 07:28 PM   #17
ground loop
Will installing the two rods to the panel ground create an alternative path to ground and therefore cause a ground loop in my circuit panel?
I am concerned about electrical shock from ground difference potentials. I read some postings regarding alternative paths to ground and it is a bit scary.
Will the ground rods cause problems , since they are an alternative path to ground?
Any help is appreciated, I am confused.
nightrook is offline   Reply With Quote
Old 09-24-2009, 07:30 PM   #18
What is a ground loop? I am concerned about that.
Old 09-24-2009, 07:49 PM   #19
Rewards Points: 266
A ground loop is a bare copper wire buried in the ground in a loop fashion as another means to create an earth electrode. (Just like a ground rod) Just bond the water main like we said before, and install your ground rods. Relax.
Replacing Double-Pane Windows RSJ0316 General DIY Discussions 1 09-16-2009 07:31 AM
Oversized Breaker djdragan Electrical 28 09-03-2009 01:09 PM
Alternative to replacing appliances neondanger Appliances 1 06-27-2009 10:01 PM
Portable breaker panel? minameismud Electrical 15 02-24-2008 12:57 PM
