Replacing Main Breakers - Electrical - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 1 Post By BluegrassGuy
  • 1 Post By Wiredindallas
  • 1 Post By MrElectricianTV
  • 2 Post By ktownskier
  • 1 Post By ktownskier
Old 06-10-2019, 08:35 AM   #1
Rewards Points: 764
Replacing main breakers
I'm replacing the main breakers on my panel. The panel is GE - it lists the compatible breaker types. See pic.
My local HD has a compatible 100amp breaker in stock. However, it doesn't list it as a main breaker.
I looked on amazon at the same breaker and the Q&A section gives conflicting information on whether this breaker can be used as a main.
How can I tell if a breaker can be used as a main?
https://www.homedepot.com/p/GE-Q-Lin...100P/100686450
Replacing main breakers-screen-shot-2019-06-10-9.34.48-am.jpg   Replacing main breakers-img_5132.jpg
jaketrades is offline   Reply With Quote
Old 06-10-2019, 08:55 AM   #2
Rewards Points: 692
Re: Replacing main breakers
That's just a standard breaker. The GE panel takes a special breaker with additional lugs on it that attach to the bus bars. I believe it was called a GE Master Main.
But for safety's sake, I would hire a licensed electrician for this. The wires feeding the main are always live, unless power is de-energized by pulling the meter -- which your power company may not allow anyone other than an electrician to do.
jaketrades likes this.
BluegrassGuy is offline   Reply With Quote
Old 06-10-2019, 11:36 AM   #3
Rewards Points: 58
You can only use that breaker as a main by using a retaining clip to secure it from being removed. I believe your panel has a plate which holds the breaker pictured and connects to the lugs on the panel. It has a small locking washer which holds the old breaker in place which you cannot remove to replace the breaker. If so, you can buy the replacement base with or without the breaker. Lets see the old panel breaker.
Wiredindallas is online now   Reply With Quote
Old 06-10-2019, 01:20 PM   #4
Rewards Points: 2,076
I think the new main breakers are required to be rated for 22,000 amps interrupting current. It would have on the labeling 22K IC. The one in your photo is 10K IC.
John Grabowski
MrElectrician.TV
MrElectricianTV is offline   Reply With Quote
Old 06-10-2019, 01:45 PM   #5
Rewards Points: 1,550
This is the main breaker for a GE 125 amp panel.
Here is the link to the item at Home Depot. It is 22K IC as MrElectricianTV suggests.
https://www.homedepot.com/p/GE-Power...00CP/100193156
The only stupid question is the one you DON'T ask!
Most of all, have fun! It ticks people off and ruins their day.
ktownskier is online now   Reply With Quote
Old 06-10-2019, 03:44 PM   #6
Rewards Points: 764
Old 06-10-2019, 05:54 PM   #7
Rewards Points: 58
Yes, the pic from home Depot is it. Only thing, the pic doesn't show both bars to attach to the panel lugs.
The Following User Says Thank You to Wiredindallas For This Useful Post:
jaketrades (06-10-2019)
Old 06-10-2019, 07:22 PM   #8
Rewards Points: 1,252
Why?
Sent from my iPad using Tapatalk
curiousB is online now   Reply With Quote
Old 06-10-2019, 07:25 PM   #9
There were a lot of accessories available. I just didn't want to post everything.
But, here it is: Click here
The Following User Says Thank You to ktownskier For This Useful Post:
Old 06-11-2019, 07:51 PM   #10
Rewards Points: 764
Ordering these from HD. Thanks!
Old 06-12-2019, 11:44 AM   #11
Rewards Points: 764
Hereís a pic of the 3 apartment breakers + the hallway/cellar breaker.
The breaker I originally posted on is labeled 3rd.
It has a #8 wire leading to a subpanel on the third floor. Iíll need to replace that wire.
The panels for the 1st and 2nd floor are the same brand panel as the 3rd.
The hallway/cellar breaker is a Westinghouse.
Iím thinking if I have an electrician in here replacing the main breaker on the 3rd floor panel, I might as well replace the 1st and 2nd floor breakers.
I donít anticipate needing more power in the hallway/cellar.
Old 06-18-2019, 03:06 PM   #12
Rewards Points: 2
Breaker can be used as a main. You have to use a hold down with it.
bobbylivewire is offline   Reply With Quote
Old 06-18-2019, 08:37 PM   #13
Rewards Points: 304
Welcome to the forum bobby. Its great to have pro's on site.
If it worked before you worked on it. You did something wrong.
