Replacing A Lightswitch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2010, 05:03 AM   #1
replacing a lightswitch
I have a brass lightswitch (to replace the old plastic one)
the new one has L1 & L2 on it,
Please can someone tell me which way round does the wiring goes, as it keeps blowing the light fuses.
the house wiring colours are red black & green.
jazzzsingr is offline   Reply With Quote
Old 01-06-2010, 06:05 AM   #2
Assuming your wiring is based on "standard" convention, green would be ground, attached to the grounding lug on the switch. Black and red would be the switched pair, hooking one to L1 and the other to L2. A switch does nothing more than establish or break contact between to conductors, so I expect it not to matter which of the red or black go to L1 or L2.
It is possible that your blowing of circuit breakers has nothing to do with your switch wiring. Is it possible you have a failed (shorted) light fixture? Have you performed any maintentance which could have damage wiring?
oberkc is offline   Reply With Quote
Replacing Windows? Kyle Remodeling 13 12-17-2009 07:03 PM
Replacing Light Switch & Outlet, but now I'm confused. ego1138 Electrical 7 04-25-2009 04:49 PM
Replacing sliding patio door problems marlinpuppy Building & Construction 2 02-22-2009 08:11 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 07:27 AM
