Replacing Lighted Medicine Cabinet With Sconces - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2015, 04:46 AM   #1
Rewards Points: 12
Question
Replacing lighted medicine cabinet with sconces
I am updating a vintage bathroom in a 90yo house. The bathroom was probably remodeled some time in the 1950s. The walls are plaster and lath. I don't know the state of the wiring behind the cabinet because I haven't removed it yet, but I do know with certainty that there is no knob and tube in the house.
My existing recessed medicine cabinet has two fluorescent lights that are incorporated into the unit. There is a toggle switch on one (that controls both lights) and an outlet on the other. I will post a picture once I figure out how to do that. The cabinet will be replaced with a wall mounted cabinet and I intend to add sconces for lighting.
The light switch for the ceiling light does not control the medicine cabinet, so I'm thinking I can add a light switch/outlet combo when I install the lights. I know it will have to be GFCI because it is above the sink.
I have replaced fixtures before but this will be my first time adding a switch and moving wiring. Before I commit to changing the lighting, what kind of potential problems should I consider?
Herself-DIY is offline   Reply With Quote
Old 10-23-2015, 05:09 AM   #2
Licensed electrician
Rewards Points: 3,592
Lighting does not require gfi protection. The receptacle does.
If the wiring is not grounded it should not be extended.
Old 10-23-2015, 05:32 AM   #3
Rewards Points: 12
Jim, are you saying that my existing wiring may not be grounded? If so, I suppose I will have to hire an electrician to run new wire back to the panel.
Old 10-23-2015, 06:51 AM   #4
I just saw your location . I know the rules are much stricter there.
You probably have metal conduit that acts as your ground.
Metal conduit is not as diy friendly as other methods .
Old 10-24-2015, 06:23 PM   #5
Rewards Points: 12
Here is a picture of the medicine cabinet and a close up of the wires, which are located inside the top of the cabinet. Can someone tell me what I'm looking at in there?
Replacing lighted medicine cabinet with sconces-2015-10-24-18_1445728955735.21.02.jpg   Replacing lighted medicine cabinet with sconces-20151024_145840-1_1445728969049.jpg
Old 11-18-2015, 05:41 AM   #6
Rewards Points: 12
Update:
I called an electrician (actually called several) for a quote after removing the cabinet and discovering that the original wiring is BX. When I pulled the permit for the remodel, I also found that code requires that I add a receptacle above the sink on a dedicated circuit. So, two new boxes and a new wire going back to the panel. Cha-ching.
Surface Mount Medicine Cabinet Help Please! ReallyWantsToBe General DIY Discussions 4 05-12-2015 05:33 PM
Receptacle in Medicine Cabinet: Code Compliant? bpSF Electrical 5 08-31-2013 04:13 PM
Replacing just the kitchen cabinet doors? imola ghost Remodeling 7 02-24-2010 11:03 AM
Replacing medicine cabinet lstoughton Carpentry 1 06-25-2009 06:20 AM
Replacing cabinet hinges bethd8384 Carpentry 6 04-13-2008 12:47 AM
