Replacing Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 08-11-2013, 02:48 PM   #1
Replacing light fixture
I have a two car garage that has two single lights, operated with one switch. I want to replace both lights with fans. When I took down the first light, I noticed that there were 2 red wires and one white one attached to the unit. I'm not used to seeing anything other than a white, black, and green. Anyone have any idea what I should do? Thanks in advance.
bobmundo is offline   Reply With Quote
Old 08-11-2013, 02:56 PM   #2
Rewards Points: 19,008
Most likely a switch loop wire.
http://www.bing.com/images/search?q=...electedIndex=3
Going to have to replace the boxes to fan boxes to support the weight.
Old 08-12-2013, 11:34 AM   #3
Rewards Points: 2,528
DO you have conduit in which the individual wires are run to the devices? Is this what you see??
hammerlane is offline   Reply With Quote
Old 08-12-2013, 11:35 AM   #4
Is this what you expected to see? Electricity does not care what color the insulation is on the wire.
As a not I do not show any ground wires for ease of drawing.
Old 08-12-2013, 08:36 PM   #5
I’m just a newbie but I was betting on the first picture also. But wouldn’t that actually be not good because it implies (I think) 2 wires (the reds) under one screw on the fixture? I know people do that because someone wired one of my porcelain fixtures like that.
But as far as I understand you should use a pigtail, 2 wires under one screw is not a reliable connection? Is that true?
agoodboy is offline   Reply With Quote
Replacing a light fixture JELLY DONUT Electrical 4 01-20-2015 10:07 PM
Replacing circular fluorescent light fixture - grounding issue DynamoDan Electrical 13 05-10-2013 03:57 PM
Covering the light fixture electric box firsttimeremode Electrical 57 09-18-2012 12:50 PM
Three light fixture only one light works jenwoode Electrical 1 09-21-2010 12:08 PM
Replacing kitchen sink light fixture TrishaC Electrical 3 07-04-2010 01:14 AM
