Replacing A Breaker - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-14-2010, 01:08 PM   #16
Grand Tortoise
Send a message via AIM to Daggerhart
And if they are charred/burnt/etcetera, what do I have to do at that point? Is it just something that can be cleaned, or are they permanently damaged at that point? I can't look right now as I'm out shopping, but I'll check as soon as I get home.
Daggerhart is offline   Reply With Quote
Old 03-14-2010, 01:10 PM   #17
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
in some circumstances the bus can be cleaned BUT most of the time, you need to replace the panel. It is something that needs to be seen to be able to really say yes or no.
If you have some empty slots in the panel, you may be able to simply blank off the space where the bus is burned and place the new breaker in an open couple of slots.
Old 03-14-2010, 06:15 PM   #18
Grand Tortoise
Hey everyone,
The swap went fine, there was nothing wrong with the busbar or panel, just a bad breaker. Thanks for the help!
Old 03-14-2010, 06:21 PM   #19
Just call me Andrew
Rewards Points: 1,032
When you shut the main breaker off, keep in mind... the two wires that feed the main breaker are LIVE. The two screws or big lugs on your main breaker are always live, even when the main breaker is off. Do not touch them!
Andrew
secutanudu is offline   Reply With Quote
Old 03-15-2010, 11:38 AM   #20
Grand Tortoise
Yeah, I got the exact same advice from my father before doing the work, was very useful to know!
Thanks for all the advice.
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 08:52 AM
Need help, breaker unstable Atroxx Electrical 16 08-08-2009 10:53 AM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 11:18 AM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 02:44 PM
