Replacing Bathroom Exhaust Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 08-19-2009, 03:11 PM   #1
I have considered replacing the exhaust fan in my bathrooms to something a lot quieter. The house has sheetrock. I could do it one of two ways, from the roof or cut a bigger hole in the sheetrock and then replace the hole with a new piece of sheetrock. This would be more work, but what I’m concerned about is the insulation in the attic. It is the blown in stuff, a 1 yr old house and if I go walking up there, I will be stepping on it, pushing it down, making it less effective….
Any advice?
Curtis
1simple is offline   Reply With Quote
Old 08-19-2009, 03:30 PM   #2
If you can access it from the attic it will be a cleaner installation with no drywall repair/paint. The vent pipe will be easier fron topside also.
Don't worry about the insulation but stay on the joists
Replacing ex fans from the bottom side is a PITA.
220/221 is offline   Reply With Quote
Old 08-19-2009, 07:32 PM   #3
Licensed electrician
Rewards Points: 3,740
You can wiggle your foot thru the insulation so not much gets disturbed. You can also fill in the holes as you leave. Wear a dust mask.
Bathroom exhaust fans PirateKatz HVAC 7 11-18-2008 03:09 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Bathroom Exhaust Fan Ducting drtpdee HVAC 1 03-03-2008 06:47 PM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 07:59 AM
