Replacing Bathroom Ceiling Heater... - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 06:57 PM   #1
replacing bathroom ceiling heater...
I have three ceiling units in both bathrooms; a seperate unit for fan, one for light, and one for heat all with seperate switches/controls. These were installed in 1970's and are now quitting. Should I replace each separately as they expire or buy a combination unit such as a light and heater together, or light, heater, fan, etc. I would then have to redo the ceiling when units are taken down. How do I judge a heater or unit that is a 4" duct, etc. Broan, Natulius, and other makers offer some based on duct size. Right now, I have heater problems in both which is controlled by a thermostat. Thanks very much for help.
DIYDI100 is offline   Reply With Quote
Old 01-09-2010, 07:46 PM   #2
Licensed electrician
Rewards Points: 3,660
Most of the combo heat/vent/light units require their own circuit. You could replace the separate unit IF the circuit was only for those units or you would need to run a new circuit. With 2 bathrooms you would need two circuits.
Old 01-09-2010, 08:34 PM   #3
Thumbs up
The advice from here is to replace the present, separate units with a combination unit for each bathroom. I had very good experience with a combo unit and a combination (triple) switch. Meanwhile, some of the problems you are having with the heat could be traced to the thermostat, which, in the very short run, could be replaced.!
spark plug is offline   Reply With Quote
Bathroom Ceiling Installation MikeyP Building & Construction 9 05-02-2009 02:54 PM
Replacing ceiling fan on cathedral ceiling? wizzy Remodeling 1 03-22-2009 03:04 PM
repainting bathroom ceiling Woertendyke Painting 1 09-11-2008 09:06 PM
Painting or Replacing Canister Ceiling Lights justagirl Electrical 1 07-14-2008 03:38 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
