Replacing 80's Light Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2018, 12:34 PM   #1
Rewards Points: 4
Replacing 80's light switches
Hi everyone, I'm new to the chatroom and I'm hoping someone here can tell me if I did something right (or wrong!).
I'm replacing the switches in a double gang box that was installed in the 1980's (one is the light and the other is the fan). I've done several other outlet and switch replacements in the house, but this one had something different.
The new switches of course have a ground wire terminal, but the old ones do not. However, there are 4 ground wires in the box that are all just wound together. (As an aside, I don't know why there are 4 wires coming into the box since it's only going out to 2 things. It sort of appears that there are 2 power sources coming in that are wound together before the first switch.) I just left the ground wires as-is and hooked everything back up with the new switches the same way as the old ones.
Should I have connected the ground wires to the switches?
burgoo1 is offline   Reply With Quote
Old 06-01-2018, 01:13 PM   #2
retired framer
Rewards Points: 970
Re: Replacing 80's light switches
Power comes and goes and is also feeds the light and fan.
You have power coming in and going on to another light or outlet. So four makes sense from that cluster of grounds you should also have tied to the switch..
Old 06-01-2018, 01:31 PM   #3
Very Stable Genius
CodeMatters's Avatar
Rewards Points: 802
Switches aren't required to be grounded up here except by means of the
6-32 screws which attach them to the box. If the box is metal your switch
straps will be gnd'd this way and I wouldn't bother changing it.
CodeMatters is online now   Reply With Quote
Old 06-01-2018, 01:32 PM   #4
hkstroud's Avatar
Rewards Points: 6,694
Yes. Find a short piece of ground wire about 8 inches long. Add it to the bundle of ground wires. Then warp it under the ground screw of one switch (about mid way of the length) then connect the end to the other switch ground screw.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 06-01-2018, 01:38 PM   #5
retired framer
Rewards Points: 970
The wire is copper??
Tags
double gang , electrical , electrical box , switch box , switches
Replacing 3 Diva Switches and 2 "3 way" switches with Grafik Eye QS Dimmer HTFreak Electrical 0 05-04-2016 08:53 AM
Mercury light switches av-geek Electrical 11 07-31-2012 08:38 PM
Replacing light w/ ceiling fan, 3 switches? burnt03 Electrical 5 07-06-2012 08:39 PM
Replacing old switches RyanS2000 Electrical 4 09-11-2011 03:21 PM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 11:16 AM
