Replacement Wall Switch For Small Box - Electrical - DIY Chatroom Home Improvement Forum
Old 12-16-2016, 01:55 PM   #1
Rewards Points: 322
Replacement wall switch for small box
This old house has small volume metal boxes with metal conduit. The original SPDT switch I want to replace has a standard size bracket, but a very small body. It easily fits the box, but a modern switch has a larger body and terminals in different locations. Even if it fits, the wires may not reach.
Is there a source for old house electrical?
tns1 is offline   Reply With Quote
Old 12-16-2016, 02:30 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,124
Re: Replacement wall switch for small box
It sounds like you might have "despard" switches.
Old 12-16-2016, 02:38 PM   #3
Rewards Points: 322
No, I believe these are Pass & Seymore, circa 1930s. The internals of the switch are different from the modern rocker contact design. Instead they use a fan-shaped wiper which allows the switch body to be narrow. It is about the same size as the ones you posted.
I see the despard style is P&S, and available from several places along with the vertical mounting strap I would need, thanks.
Wiring in a light fixture with a switch on the wall and on the fixture crescere Electrical 5 10-04-2015 01:19 PM
Which wires?! To Install Universal Ceiling Fan Remote Wall Switch. guht Electrical 2 09-25-2015 04:19 PM
Slight crackling/popping sound in wall switch JayBird Electrical 3 08-06-2010 11:37 PM
I'm having trouble replacing a wall switch jamesjames Electrical 6 03-14-2010 03:44 AM
Wall Switch sue Electrical 4 02-06-2005 08:05 PM
