Replaced A Wall Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 07-01-2010, 11:51 AM   #1
replaced a wall switch
I replaced a wall switch . When I turned the power back on and turned on the switch, there were sparks and the circuit breaker tripped. What did I do wrong?
remicat is offline   Reply With Quote
Old 07-01-2010, 11:59 AM   #2
What type of switch ?
How many wires in the box ?
Sounds like you crossed 2 hots
Old 07-01-2010, 12:06 PM   #3
There are 3 wires in the switch. I put the black one on the left, the uncoated one on the upper right and the white one on the bottom right. This is the way they were when I opened the switch plate.
Old 07-01-2010, 12:49 PM   #4
Do work
Rewards Points: 81
Can you post a picture?
liquidvw is offline   Reply With Quote
Old 07-01-2010, 03:05 PM   #5
Licensed electrician
Rewards Points: 3,654
Only the colors of the screws matters. Position is relative to how it was installed and not all brands are setup the same way.
Old 07-01-2010, 05:13 PM   #6
Sorry to bother you. I did not know green screw means ground. But thank you for trying to help me. I switched the ground to the green screw and Voila! Success! Thank you.
Old 07-01-2010, 06:25 PM   #7
Rewards Points: 464
Good times, free fireworks!
Jim F is offline   Reply With Quote
inoperable wall switch bap Electrical 6 04-18-2010 08:15 AM
I'm having trouble replacing a wall switch jamesjames Electrical 6 03-14-2010 01:44 AM
Outlet controlled by a wall switch rwright46 Electrical 5 04-30-2009 05:00 PM
Motion switch wired to two circuits Sibkuz Electrical 2 04-22-2009 07:31 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
