Replaced Electrical Outlet-- Main Breaker Tripping - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2010, 10:41 PM   #1
We have a regular dual receptacle and all of a sudden the bottom half stopped working. I took out the receptacle and saw there are 4 wires--red, black, white & bare copper. The part of the receptacle where the red wire was attached was charred, and the wire itself is a little bit black at the end. I bought a new receptacle and attached the wires exactly as they were on the old one-- black & red in the copper screws, white in the silver, and bare ground wire in the green. Now when I try to use the receptacle, neither outlet works and it trips the main circuit breaker.
What is the problem? Could it be the red wire, since it is a little burnt at the end? Also, I couldn't get a tight fit on the ground wire in the green screw-- could that be the problem a well?
Meliss0880 is offline   Reply With Quote
Old 09-11-2010, 11:02 PM   #2
A "Handy Husband"
rjniles's Avatar
Look at the old receptacle, is the brass tab between the brass screws broken out? If so, you need to break it out on the new receptacle - brass screws only, not the silver screws.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 09-12-2010, 03:03 AM   #3
" Euro " electrician
frenchelectrican's Avatar
Did you look at the old receptale due it is a split set up and to order to work properly you need to break the tab between the two.
Did it trip just one breaker or two breakers ? if two then I know you have two diffrent circuits run in there.
Merci.
Marc
Bad main breaker? jm8891 Electrical 13 11-09-2013 09:32 AM
Circuit Breaker trips when I plug into an outlet Alex in Orlando Electrical 3 09-05-2010 01:04 AM
Main 50 amp breaker in meter room keeps tripping Dennis Diaz Electrical 7 04-21-2010 07:42 AM
Intermittent circuit, breaker not tripping lucabrasi Electrical 5 03-14-2010 07:03 PM
Main breaker tripping M. Ready Electrical 27 02-21-2009 09:18 AM
