Replace Pullchain Controlled Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2011, 03:59 PM   #1
Replace pullchain controlled fan
Above is a problem I'm currently trying to solve.
There was a fan with light here. I'm sure the fan's light was on a 3-way switch since there are two switches in this room that controlled the light. The fan itself (like all the rest in the house) was controlled by pullstring only. I'd like to put another fan here from a big box store (with no light on the replacement... going with recessed later). I believe the black/white striped wire (longer one in picture without the cap on it) is the one that provided power to the fan since even when I kill the breaker, my voltage tester still says it's getting power.
How can I tackle this? Any suggestions? Should I get the fan I want first and then post more pictures when I get it? I'm not afraid to hang a light fixture... I've hung quite a few, but I'm nervous with this one since the fans always have power no matter what I do... part of me thinks they must just be given power from the main feed in the breaker panel?
ALSO: Yes, I will be putting in an up-to-code box for the new fan. I just wanted to figure out the wiring problem before I got to that point.
Thanks for your help,
Nate
natedro is offline   Reply With Quote
Old 09-10-2011, 07:19 PM   #2
Rewards Points: 1,078
The black/white combo (stripped wires) are always live (for fan). The black (capped) and white combo are switch controlled (for light). You will need to find the correct breaker for the live wires and label it.
Why not install a box and wire same way with a light kit? Otherwise switches will do nothing or need to be removed. Can't have too much lighting. Alternately, you can have fan on switch instead of light and cap live wire on box.
diyorpay is offline   Reply With Quote
The Following User Says Thank You to diyorpay For This Useful Post:
natedro (09-16-2011)
Old 09-16-2011, 01:29 PM   #3
I think I'm going to go ahead and cap the striped wire and then use the fan on the hot (solid black) and neutral (white). Will this work?
Also, I can just cap the striped wire at the fixture right? I shouldn't need to worry about the switch connections?
When I go to run my recessed lights at a later date, I will add a switch for the new recessed lights (maybe with dimmer) and then another for outdoor lights which have the switch currently in the master bedroom (odd).
Thank you kindly!
Old 09-16-2011, 03:13 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 18,406
Just so it's clear.....there is NO box up there? They have the wires running in the attic and straight out that hole? Fan fan bracket was screwed into the joist?
Seeing how all wire connections must be in a box....I think it would be a stretch to say that the cap of the fan shaft could be called a box....
edit....not ragging on you....your wanting to do it right by installing a box.....I just can't believe someone would do that....was it done by the builder or the last homeowner?
ddawg16 is online now   Reply With Quote
Old 09-16-2011, 03:46 PM   #5
Well, I'm not sure who it was done by to be honest. I've only been here since April, but the house was built around 1959 - the fans had obviously been changed since they weren't that old, but who knows who did it.
All of the fans in the house are/were hung like this - they just have a huge loop screw going into the joist which the fan would hang on via hook. There is likely (haven't checked this exact spot for certainty) a junction box above the room connecting the wires from the 2 switches above this as in the other rooms I've worked on. At least in the attic there are no wire connections without a jb around them.
It should be a nice little adventure when I go to put the fan box in. I haven't had to do that yet either. I have learned so much with this damned house with all of its problems. How I am still in love with it I don't know!
Old 09-16-2011, 04:42 PM   #6
JOATMON
ddawg16's Avatar
The mantra of a true DIY'er.....it's ok.....your normal....we all have the same problem....gift....
The Following User Says Thank You to ddawg16 For This Useful Post:
gregzoll (09-19-2011)
Old 09-19-2011, 10:46 AM   #7
Update:
On a different ceiling fan (same situation, same wiring), I finally found the correct breaker and was able to cap the striped wire and install a fancy new light fixture in the dining room. Feeling all good inside.
Old 09-19-2011, 11:54 AM   #8
Rewards Points: 6,652
How in the world did they keep it from falling off of the ceiling and killing someone?
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 08:55 PM
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 02:41 PM
When to replace a furnace? stanlam HVAC 3 07-20-2010 07:21 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 07:03 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
