Replace Outdated Fixture With Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 06:03 AM   #1
Replace outdated fixture with outlet
My outdated bathroom (70ís) has a medicine cabinet with one light fixture located on each side. These fixtures are controlled by a single switch. Black, White and Ground wires run from the switch into the box behind the right fixture and then out to the left fixture. The left fixture has an outlet built into it.
I would like to move the location of and replace the right fixture with a GFCI outlet. Then move the second fixture (it will be a new fixture) above the cabinet. Is this possible? I understand that the outlet will be controlled by the switch that is ok with me.
Any help in telling he how best to accomplish this is appreciated.
derbydog is offline   Reply With Quote
Old 12-13-2011, 06:07 AM   #2
Rewards Points: 17,940
A picture would sure help.
In most cases it looks better and is easer to reach if you install a GFI in the wall instead of having to plug into a light fixture.
plummen (12-13-2011)
Old 12-13-2011, 03:18 PM   #3
Julius793's Avatar
It's going to depend on how far u wana move the fixtures, and if u wana cut Sheetrock or not. However one suggestion, instead of having the switch control the gfi, put in a 2 gang box by the switch and put the gfi there. Feed power first to gfi then to the switch. (make sure all on the line side so if it trips it won't turn off the lights)
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 12-13-2011, 07:01 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 952
Please don't type like you are texting!
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 12-14-2011, 12:53 AM   #5
Julius793's Avatar
I will try
The Following User Says Thank You to Julius793 For This Useful Post:
jbfan (12-14-2011)
New GFCI Outlet From Existing Light Fixture? krsnyder8 Electrical 4 08-07-2011 06:23 AM
GFCI outlet failed in a rain storm, now has no power! Kaybee33 Electrical 5 12-28-2010 05:38 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
How To Replace This Fixture? JackOfAllTrades Interior Decorating 7 09-25-2008 04:56 AM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
