Replace 2 Prong Outlets With 3 Prong Outlets - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-09-2009, 01:33 PM   #16
Rewards Points: 2,350
Originally Posted by Wildie View Post
Hmmm! Interesting! I guess I don't quite understand how these effect my kitchen toaster!
As opposed to your bathroom toaster?
Old 03-09-2009, 01:48 PM   #17
Originally Posted by Gigs View Post
Wildie the primary benefit is that if the chassis becomes energized, then as soon as someone touches it, the GFCI will trip. They will get a little bite for a few milliseconds.
A real ground would operate the circuit breaker as soon as the chassis became energized. No one need touch it.
In the case of an intermittent ground fault, with ground, the CB would trip as soon as the first solid fault. With the GFCI and no ground, this condition could exist for years.
These differences exist even with your kitchen toaster.
What happens in the meantime, before its a solid fault?
Old 03-09-2009, 01:49 PM   #18
how did you know about that?
Old 03-09-2009, 04:40 PM   #19
DIYer
If it's a relatively high resistance fault, it could start a fire from heating effects. If it's an arcing fault that isn't solid enough to trip a CB, that's what an AFCI is supposed to catch.
Nothing can catch 100% of faults. A GFCI with proper ground can catch a lot of them though.
Gigs is offline   Reply With Quote
Old 03-09-2009, 06:00 PM   #20
Thanks Gigs, don't have any of those AFCI's though!
Old 03-10-2009, 11:20 AM   #21
I think rpsjn4 has left the premises. . .
Old 03-10-2009, 11:44 AM   #22
Husband probably convinced her that he "can" do it himself...
Sad isn't it? People putting other peoples live in danger...
rgsgww is offline   Reply With Quote
Old 03-10-2009, 12:03 PM   #23
Or he gave up or he is going to hire someone or . . .
OP feedback makes for better replies.
Old 03-10-2009, 01:56 PM   #24
It sure does...
Old 03-10-2009, 09:20 PM   #25
Elvis has left the building.
Maybe if we mocked her husband , she would come back???
220/221 is offline   Reply With Quote
Old 01-16-2010, 07:50 AM   #26
IS using self gounded recepticles ok to use when converting?
Tekno9000 is offline   Reply With Quote
Old 01-17-2010, 01:24 PM   #27
Inspector/Instructor
codeone's Avatar
NO! Not unless you have a ground wire back to the panel.
codeone is offline   Reply With Quote
Old 01-17-2010, 01:34 PM   #28
" Euro " electrician
frenchelectrican's Avatar
Simple answer is no you can not do that if there is no ground wire or in legit EMT conduit or ground wire is there.
Merci,Marc
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Triplex Outlets jamiedolan Electrical 33 10-14-2008 06:07 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 08:59 AM
Replacements for two prong outlets? Tmb9862 Electrical 9 01-10-2007 09:11 AM
