Repeater/Remote Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2010, 10:31 AM   #1
Rewards Points: 22
Repeater/Remote switch?
I am looking for a product that will allow me to control lights that are on a single pole dimmer at one location in the room from the other side of that room? I want this 2nd switch to be installed in a gang box and look as if it was hardwired.
The problem is that i couldnt install the wiring for a 3-way switch at the exisitng location and the new location without tearing out half my ceiling. I though i had crawl space access but it doesnt go back that far in part of my house. So I was trying to see if there was some sort of device that looks as if it was hardwired, but is really no more then a remote.
Hope this explains what I am trying to do.
Thanks,
Ben
benshouse is offline   Reply With Quote
Old 02-02-2010, 10:58 AM   #2
Just call me Andrew
Rewards Points: 1,032
You can use X-10 or similar style remotes to do just what you want, but they aren't too cheap. You would need to replace your current dimmer with the x-10 style as well.
http://www.smarthome.com/_/Dimmers_L.../_/z/land.aspx
The one I just looked at requires a neutral in the switch box. It's a safe assumption they all will require it. How many wires are in the switchbox? If only two, you will need to run new wiring that has a neutral.
Andrew
secutanudu is offline   Reply With Quote
Old 02-02-2010, 06:09 PM   #3
I used Insteon switches from Smarthome, as the previous reply mentioned.
I added undercounter lights that are controlled by the main kitchen light switch. I replaced the kitchen light switch with an Insteon dimmer, and plugged the undercounter lights into an Insteon plug-in controller.
You need to 'link' the two controllers to make both control the lights. There are lots of ways to combine these switches to create virtual 3-way, 4-way or more.
The X-10 devices are cheaper, but they are subject to interference and intermittent operation. The Insteon switches use both powerline transmission and RF (radio) signals to operate.
You're going to spend $45 each for the dimmer switches. Lots cheaper than tearing out ceilings.
Here's a link to what you need (unless you have Decora-style switches):
http://www.smarthome.com/2466DW/Togg...h-White/p.aspx
houseinthewoods is offline   Reply With Quote
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
