Repeated Light Flicker - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2013, 12:12 PM   #1
Repeated light flicker
We have been having a strange issue that maybe someone can shed some light on.
We have a ceiling fan with light that is controlled by a Hunter brand light/fan dimmer switch (looks just like this). When the light is turned on, every night at approximately 8:09pm the light will flicker for about 10 seconds, then stop. It doesn't matter how long the light has been on prior (10 minutes or 2 hours) it will still flicker. I have opened up the switch box and checked the connections - everything seems fine. But I find it very strange that the light/switch appear to have some sort of an input from a clock. How would the light/switch know to flicker every night at the same time? No other lights or outlets in the house have this behavior.
I don't want to write too long of a memo here, but if anyone has any ideas or suggestions, please let me know.
Thanks,
Dustin
dshively is offline   Reply With Quote
Old 11-28-2013, 11:21 PM   #2
dmxtothemax's Avatar
Rewards Points: 7,516
Sounds like the tones used by the poco are affectting your dimer !
poco injects tones into the power lines to remotely turn off hot water systems.
Call Hunter and ask if they can advise a solution ?
dmxtothemax is online now   Reply With Quote
Old 11-29-2013, 06:34 AM   #3
Rewards Points: 17,940
Do you have a timer on your water heater?
Do you have a water softener that's timed to back wash at that time?
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
dimmer 'crossfade' when combining light circuits mitchl Electrical 8 12-11-2011 03:00 PM
2 Wires in to light, 3 Wires out, no juice on the switch prytoo Electrical 4 11-28-2011 05:24 PM
ceiling light problem al gilliland Electrical 0 11-15-2011 04:05 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
