Removing Tree Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 04-29-2010, 02:43 AM   #1
sweaty
Rewards Points: 318
I have a couple trees that the previous owner put lights on. There is a switch in the garage and the line goes underground and then up a couple trees to a light fixture.
One of these trees needs to be removed. It is actually a big split tree and there is a big crack going down the middle. We ought to remove it (them) before they fall. What do I do with the power line coming up from the ground?
sweaty is offline   Reply With Quote
Old 04-29-2010, 06:12 AM   #2
Technically, you are not supposed to mount lighting on trees, but that is not the issue. Disconnect the wire at the switch.
Old 04-29-2010, 12:27 PM   #3
Journeyman Wireman
Rewards Points: 150
If the cable if UF dig it out of the ground and pull back 10 feet. The set a GFCI in a Bell (weatherproof) box. Then you have a convenience outlet for landscape lighting or to plug in lawn equipment.
Jupe Blue is offline   Reply With Quote
Old 04-29-2010, 02:44 PM   #4
electrician
Says who?
Not the NEC. In fact, it says the opposite.
Silk is offline   Reply With Quote
Old 04-29-2010, 04:41 PM   #5
I thought they did away with it too....but
410.36 Means of Support.
(G) Trees. Outdoor luminaires and associated equipment shall be permitted to be supported by trees.
Old 04-29-2010, 10:55 PM   #6
" Euro " electrician
frenchelectrican's Avatar
I have see them { luminaires } mounted on the trees however they leave a slack due the trees will grow over the time and if not addressed the tree growth will cover up everything up if not watched in few years.
And yeah the codes still allowed to mount on the tree I know some peoples think it is nuts but for myself I thread this part very carefull if slow growth tree it is not too bad but fast growth tree forget it.
Merci,Marc
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
removing tree roots from sewer tile 4just1don Plumbing 4 09-10-2010 07:23 PM
Christmas Tree Lights timchi29 Electrical 2 11-23-2009 12:12 PM
Removing a tree stump that has grown into a fence brokenhammer Landscaping & Lawn Care 7 01-26-2009 10:32 AM
need help removing ceiling fan and installing recess lights craig83170 Electrical 1 09-06-2008 07:27 PM
