Removing Downrod From Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 05-08-2008, 10:38 AM   #1
Removing downrod from ceiling fan
I purchased a ceiling fan and downrod. The downrod was screwed into the ceiling fan and when hung it is to low. I can't get it unscrewed and I assume it is due to the thread adhesive used. Is there a way to get the downrod off the ceing fan?
pantul is offline   Reply With Quote
Old 05-08-2008, 12:42 PM   #2
Guest
You bought a used ceiling fan?
I have no idea why anyone would put Loctite on the threads. If there is no pin or set screws, just unscrew the rod. There might have been set screws at one time and the threads are damaged.
connyou is offline   Reply With Quote
Old 05-08-2008, 06:09 PM   #3
they make them so they don't come apart too easy, don't want them to wiggle free up on the ceiling, if your sure you want it apart, you could put a pipe wrench on the pipe, you may scratch it all up, just be careful not to damage the motor, and might be easier in the long run to take the blades off first, and to have someone hold onto the motor while you are turning the pipe, good luck.
DUDE! is offline   Reply With Quote
Old 05-08-2008, 07:05 PM   #4
Thank You Dude.....the only one who understood what I was asking. The fan is already down with no blades and still couldn't get it apart. Guess I will have to try the pipe wrench route. Thanks again.
Old 05-08-2008, 07:38 PM   #5
Idiot Emeritus
Rewards Points: 80
Most of these downrods have either a setscrew or a pin through them. Some are not even threaded, just a pin through the middle of the rod. They're well hidden sometimes.
Rob
micromind is offline   Reply With Quote
Old 05-12-2008, 08:49 PM   #6
Rewards Points: 77
The Hunter fan I bought last year came from the factory with Loctite on the threads.
tima2381 is offline   Reply With Quote
The Following User Says Thank You to tima2381 For This Useful Post:
detour13 (04-17-2010)
Old 04-17-2010, 08:15 PM   #7
removing a hunter fan downrod
I agree they must put lock tight on these down rods, tried wd 40 n two pipe wrenches, still cant break down rod. either going to find a lock tight remover or just cut rod to size i need.
detour13 is offline   Reply With Quote
Ceiling fan - Downrod won't screw in all the way tima2381 Electrical 8 05-02-2012 02:57 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
Question regarding removing ceiling joists... tonfan Building & Construction 9 11-18-2007 11:56 PM
ceiling fan downrod extension installation smallcrpt Electrical 3 02-12-2007 02:14 PM
