Remote Control For Light Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2010, 11:18 PM   #1
Remote control for light switch?
I have a few light switches connected to a 20 amp breaker for my bathroom. Main light, vanity light, nighlight & mood light (blue).
1) Should I only use 20 amp switches or is 15 amp okay?
2) What is the best way to make some of these switches controllable by remote? I want to turn them on when I walk into the bathroom, then turn all but the mood light off when I get into the tub.
3) I want to make the nightlight switch have a built in LED or something, so I can see the switch at night to turn it on. Any suggestions?
Thanks!
CZ DIY is offline   Reply With Quote
Old 08-23-2010, 11:02 AM   #2
Rewards Points: 320
1. 15 amp switches are fine.
2. Not sure of your question about the remote. Do you want to turn off the lights with a remote once you are in the tub? I would think that the mood light that you described would be enough light so that you could turn them off at the switch before you get in the tub.
3. They sell switches that are back lit so that you can see them in the dark.
teamo is offline   Reply With Quote
Old 08-23-2010, 11:27 AM   #3
Thanks!
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Switch/outlet - remote control devices? ccjr019 Electrical 2 12-16-2009 08:58 AM
Remote Light Switch artrail36 Electrical 3 10-02-2009 12:30 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 11:05 AM
