Refrigerator Switches Off At Fuse Box When It Reaches Thermostat Setting - Electrical - DIY Chatroom Home Improvement Forum
Old 10-14-2010, 10:18 AM   #1
refrigerator switches off at fuse box when it reaches thermostat setting
every time my Westinghouse rj442 reaches the thermostat set temp it automatically switches the safety off in the fuse box how can i repair this as my mortgage doesn't allow me to afford a newy for a while?
Tim Peakn is offline   Reply With Quote
Old 10-14-2010, 11:07 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 24,004
Is it a GFCI that is trippping or is the breaker tripping on fault? If it is a GFCI then you can change to a regular breaker. If it is tripping the breaker then you need a new fridge or the fridge serviced.
Old 10-14-2010, 03:02 PM   #3
I=E/R
a7ecorsair's Avatar
If the breaker or GFCI is tripping, how do you know the refrigerator reached the thermostat set point?
a7ecorsair is offline   Reply With Quote
Old 10-31-2010, 12:48 PM   #4
why then
my question was not based on a total synopsis about what i obviously had done before hand to narrow my problem down so perhaps my question could be answered without out going over things i had already discovered in short i was hoping i would find something i didn't now something i could use you no connect the dots a little humility never hurt anyone
Old 10-31-2010, 01:03 PM   #5
Rewards Points: 2,800
Originally Posted by Tim Peakn View Post
every time my Westinghouse rj442 reaches the thermostat set temp it automatically switches the safety off in the fuse box ...
Is the safety a GFCI breaker or just a regular breaker. If it is a GFCI breaker, try plugging the refrigerator into a receptacle on a different circuit, one fed by a regular breaker (use a heavy duty extension cord if needed).
There could be a defect in the 'fridge that causes a GFCI in the power circuit to trip but the 'fridge itself still works okay for now. Considerable troubleshooting would be needed to find the defect including knowing how to use the schematic diagram (hopefully) pasted on the back of the 'fridge.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 10-31-2010, 01:27 PM   #6
Rewards Points: 2,070
Remove GFCI and install regular receptacle see what happens, if the breaker opens post back. Post back anyway.
COLDIRON is offline   Reply With Quote
thermostat goes to malfunction mode when it reaches set temperature Bobalu HVAC 0 08-23-2010 07:35 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Least expensive Programmable Thermostat for home with automatic vacation setting Studly HVAC 2 12-15-2009 07:18 AM
cold setting starts heater on new thermostat jayres HVAC 3 10-20-2009 04:26 AM
A/C not cooling to thermostat setting? stephgpdiy HVAC 11 08-21-2009 07:00 AM
