Reconnecting A Circuit, And Tips For This? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2010, 08:03 AM   #1
Rewards Points: 184
Reconnecting a circuit, and tips for this?
Greetings!
I need to reconnect the capped orange wire on the lower left, to the 3rd circuit breaker.
I'm going to turn off the main power.
Then it look like I just unscrew it, slide the cable in, and rescrew. Similar to doing a light switch.
Is that all their is to it?
Any tips or anything else I should know?
abefroman is offline   Reply With Quote
Old 11-30-2010, 08:10 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 958
Never reconnect a wire to a breaker if you did not remove it.
You have no idea what was on the mind of the person that worked on it before you did.
Call them back and let them install the wire, otherwise you could have something blow up in your face!
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 11-30-2010, 08:41 AM   #3
Licensed electrician
Rewards Points: 3,654
Has the problem with the lift pump been fixed?
Old 11-30-2010, 08:43 AM   #4
Rewards Points: 184
Almost, working on that now.
How do I take off the plate to the circuit box? abefroman Electrical 11 11-29-2010 09:15 PM
Circuit dead without tripping breaker? rpfeinman319 Electrical 3 03-20-2010 09:02 PM
Help on wiring and circuit breakers udfxrookie Electrical 3 07-19-2009 09:30 AM
High Hat Install On Old Circuit yellowrubiu Electrical 18 02-04-2009 06:49 PM
Adding a new circuit breaker ksl420 Electrical 9 05-23-2006 10:25 AM
