Recommended Box For Exterior Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 12-02-2009, 12:12 AM   #1
Rewards Points: 518
Recommended box for exterior fixture
What metal box would you suggest for use on an exterior wall made of OSB sheathing with dutch vinyl siding? Around here I mainly see 4" diameter 1/2" depth pan boxes being used but that limits your options. Curious to hear other opinions.
n0c7 is offline   Reply With Quote
Old 12-02-2009, 12:48 AM   #2
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
There are light blocks made by a company named Arlington that come with the box built right in to the block.
These light blocks also come equipped with different size laps to properly fit your vynil siding for a custom look.
Union County, NJ, Licensed Electrician
Classic Electric, LLC, Rahway, New Jersey
Magnettica is offline   Reply With Quote
Old 12-02-2009, 06:42 AM   #3
Just call me Andrew
Rewards Points: 1,040
Here is a link to the Arlington fittings - they sell them at home depot, but not Lowes. They also probably sell them at an electrical supply.
http://aifittings.com/k_6.htm
secutanudu is offline   Reply With Quote
recommended slab thickness? walkman Building & Construction 6 11-16-2009 06:19 AM
Sealing old grout recommended? bifjamod General DIY Discussions 1 04-05-2009 07:26 PM
Recommended low pitch roofing! Wildie Roofing/Siding 5 09-15-2008 09:38 PM
Recommended way to attach firring strips to Drylock wall? jbwaechter Building & Construction 1 04-29-2007 04:08 PM
