Recommendation For A Panel Change - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2013, 11:52 AM   #1
Rewards Points: 121
Recommendation for a Panel Change
I am thinking about changing my panel. I have 150 amp panel with about 20 slots.
All are full and alot are "twins". I would like to get a bigger panel with about 40 slots so I can add more down the road and clean up the twins.
Here is my problem. My feeders are Aluminum. They were copper but the local utility moved my service from one side of the house to the other. (It traveled over a future pool), so they moved it free of charge and put in Aluminum from the meter to the panel.
150 Amps are fine and no need to upgrade to 200.
Can you recommend any panels that would take Aluminum feeders. I will be shopping at the big box stores.
Also will I need the AL/CU grease as well?...I forget what it is called.
Thank you all. Have a great day!
icepal1999 is offline   Reply With Quote
Old 08-12-2013, 12:16 PM   #2
Electrical Contractor
kbsparky's Avatar
Most any panel available these days are rated for either copper or aluminum conductors.
The "grease" you are referring to is commonly called "noalox" or "De-Ox"
-KB
Old 08-12-2013, 01:22 PM   #3
Rewards Points: 121
Thanks KB.
Any personal recommendations - GE, Murray, etc?
Do I need to put "noalox" on the Aluminum conductors before putting them in the main breaker and tightening them?
Old 08-12-2013, 01:35 PM   #4
kbsparky's Avatar
I prefer Square D type QO panels.
More expensive, but worth the difference for me, at least.
Inhibitor compound is not required to be used on the mains.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Oso954 (08-12-2013)
Old 08-12-2013, 01:43 PM   #5
Philly Master's Avatar
Rewards Points: 516
Seimans PL series ...copper bus and plenty of neutral connection spaces...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Sub Panel over 10g-2 Help Needed hamblinh Electrical 30 01-18-2013 07:46 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 03:35 AM
Need to change my electrical panel? 2nd opinion needed I_have_questions Electrical 60 01-30-2009 09:38 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
