Recessed Lighting Vs Insulation - Electrical - DIY Chatroom Home Improvement Forum
Old 05-17-2010, 10:39 AM   #1
Rewards Points: 358
Recessed Lighting vs Insulation
Sort of has to do with electrical so I will post here. The previous owner of our house went a little crazy with recessed flood lighting, we have 56 to be exact! Which would be fine if the house was larger that 900 sq ft haha
When up in the attic I noticed no block outs of the insulation, the insulation is over all the lights. I assume this is a fire hazard? What is the correct approach to fix the problem, just cut a section of the insulation away from the lamps?
cbzdel is offline   Reply With Quote
Old 05-17-2010, 11:30 AM   #2
Licensed electrician
Rewards Points: 3,654
The correct approach would be to see if IC, insulation contact, housing were used. Check for a label either inside or outside the housing for the IC listing. If they were you have no issues. If non-IC housing were used you will need to remove the insulation 3" from the housings. This will contribute to higher energy bills, but does remove the fire hazard.
insulation around recessed lighting wiggs Electrical 8 03-17-2011 01:28 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Boxing recessed lighting for insulation topher0524 General DIY Discussions 12 02-16-2009 01:36 AM
Covering recessed lighting with insulation bob with 4 dormers Building & Construction 2 12-04-2008 07:26 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
