Recessed Lighting Solution For Joists Not 16" OC. - Electrical - DIY Chatroom Home Improvement Forum
Old 12-20-2016, 01:41 PM   #1
Rewards Points: 194
Recessed Lighting solution for Joists not 16" OC.
Hey guys so i wanted to install recessed lighting in my basement but the joists are not 16" OC. most are between 12" and 14" OC and thats less than the minimum range of the hanging rails that comes with most cans.
Also, i am not ready to install drywall, but do need the light so i wanted to use new work cans and not retrofit cans.
Any ideas on how I can install the new work cans on joists that are so close apart from each other?
DeeEyeWhy is offline   Reply With Quote
Old 12-20-2016, 02:06 PM   #2
Rewards Points: 2,084
Re: Recessed Lighting solution for Joists not 16" OC.
I use Halo H7 cans and do not have a problem cutting the hanging brackets if needed.
John Grabowski
MrElectrician.TV
MrElectricianTV is offline   Reply With Quote
Old 12-20-2016, 02:34 PM   #3
Oso954's Avatar
Rewards Points: 1,902
As MrE TV said, By cutting off (or in some cases snapping off) the tail ends of the hanger bars, the bars will collapse down smaller.
12 inch OC joists should not be a problem.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Jim Port (12-21-2016)
Old 12-20-2016, 02:41 PM   #4
Rewards Points: 194
Hi MrElectricianTV,
Thanks. I have never used Halo cans, only CE cans and the hanger bars do not feed through to be trimmed off.
I assume these are the cans you speak of:
http://www.homedepot.com/p/Halo-6-in...-202522896-_-N
Old 12-21-2016, 08:08 AM   #5
Electrician
Rewards Points: 986
I would go with this style of light, quick and easy install and no worries of the joist being in the way. These will fit right under the joist if need be.
http://www.lithonia.com/commercial/w...l#.WFqMHNQrL4Y
I would run all your wire and install a few of these for temporary lights.
http://www.habetandhabet.com/index.p...&productId=838
I did this in my basement and it worked great.
darren is offline   Reply With Quote
Installing recessed lighting into bedroom with bx Gee rock Electrical 6 10-24-2012 05:29 PM
Recessed Lighting Layout - HELP foxwoods321 Electrical 12 02-24-2011 09:32 PM
What kind of recessed lighting and bulb? Sardinia Electrical 2 01-28-2011 11:03 AM
Need lighting control solution mmccarty Electrical 9 08-25-2009 09:13 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
