Recessed Lighting Shadow Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 11-27-2013, 04:23 PM   #1
Rewards Points: 194
Our 20 year old home has a 6" recessed light in front of the fireplace. The position of the light casts a dreadful shadow on about half of the area below the mantel. The problem is at its worst when only the recessed light is on. Repositioning the moveable light ball does not help. Is there a newer replacement recessed light that I can have installed that will solve this problem? Or is there another solution.
Note: When the four lights on the fan are "on" the shadow is much less severe but we prefer to use just the recessed light.
The attached photoshopped image may help illustrate the issue. I circled the recessed light fixture. The room is also brighter because of the flash and natural light.
Thank you in advance.
sore thumb is offline   Reply With Quote
Old 11-27-2013, 04:49 PM   #2
have you tried a dimmer switch?
itsnotrequired is offline   Reply With Quote
The Following User Says Thank You to itsnotrequired For This Useful Post:
sore thumb (11-27-2013)
Old 11-27-2013, 04:52 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 23,804
Unless you change the position of the light or the mantle I don't see how you would expect to eliminate the shadow. A dimmer would make the shadow lees visible.
The Following User Says Thank You to joed For This Useful Post:
Old 11-27-2013, 04:53 PM   #4
Rewards Points: 194
The recessed light has a dimmer switch yet makes no difference except the overall light is dimmer.
Old 11-27-2013, 04:56 PM   #5
Rewards Points: 194
Would a new fixture with a larger degree of tilt help? See attached: http://www.lowes.com/pd_549132-38269...7C1&facetInfo=
Old 11-27-2013, 05:21 PM   #6
Rewards Points: 17,912
You have an arrow pointing to the light but you can not even see it because it's to close to the fan.
Old 11-27-2013, 06:23 PM   #7
dmxtothemax's Avatar
Rewards Points: 7,466
Why don't you put some LED stripe lighting under the mantle ?
Problem solved !
Otherwise you have to move the position of the downlight.
But unless its a long way out, the mantle will always cast some shadow.
dmxtothemax is online now   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Old 11-27-2013, 07:51 PM   #8
Rewards Points: 194
Problem solved !
Thank you for your suggestion. Will give it a try. Actually, the recessed light is too close.
Old 11-28-2013, 12:23 PM   #9
Bill Kearney
Rewards Points: 1,174
I'd be inclined to say move the light. Possibly changing out to more than one, in a smaller size, with a different style of baffle. Patching drywall and repainting isn't all that difficult for a pro, and that's a pretty quick kind of job.
wkearney99 is offline   Reply With Quote
Installing recessed lighting into bedroom with bx Gee rock Electrical 6 10-24-2012 05:29 PM
Kitchen fluorescent to LED recessed lighting changeout speedytahiti Electrical 1 01-05-2012 07:04 PM
Cover for Recessed Lighting Trim Model HBR635(T49) aghahary Electrical 4 07-23-2010 04:30 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Recessed lighting - old work problem Plasmech Electrical 7 04-06-2008 01:07 PM
