Recessed Lighting Makeover - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2010, 09:24 PM   #1
Lightbulb
I plan on enclosing some recessed lighting with shower trims (glass lens with a shower trim). The units currently have 65 watt bulbs in place. Once the units are fully enclosed, what wattage should I use going forward? I am worried about heat build-up once the units are enclosed. Thanks!
CarolinaW is offline   Reply With Quote
Old 08-09-2010, 09:33 PM   #2
Licensed electrician
Rewards Points: 3,672
The trim will tell you what bulbs can be used with that trim. Most likely it will be a standard A type bulb with a 40 or 60 watt max.
CarolinaW (08-09-2010)
Cover for Recessed Lighting Trim Model HBR635(T49) aghahary Electrical 4 07-23-2010 05:30 PM
Recessed Lighting Noob Install Question?? help! windycitystyle Electrical 1 01-20-2010 12:53 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 10:47 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 11:21 PM
