Recessed Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2010, 11:43 PM   #1
Recessed lighting
Can I change out eyeball light trim for recessed light trim without having to change out the entire lighting system? I purchased screw in pendant lights and they will not meet flush with the ceiling because of the eyeball feature. I didn't realize that the edging and the eyeball "socket" are all one piece. I thought I could remove the socket so the new fixture would meet flush. I'm not a wiz with electrical stuff so if I could avoid changing out the whole unit that would be great!
sbrandolph is offline   Reply With Quote
Old 08-13-2010, 06:01 AM   #2
The recessed can should sit flush with the ceiling, and trim rings can be changed as desired. But some trim rings limit the size of the lamp that can be used. See the label inside the fixture.
Cover for Recessed Lighting Trim Model HBR635(T49) aghahary Electrical 4 07-23-2010 04:30 PM
Recessed Lighting Noob Install Question?? help! windycitystyle Electrical 1 01-20-2010 11:53 AM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
