Recessed Light Issue? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2010, 09:19 AM   #1
Rewards Points: 121
Getting ready to have spray foam and drywall hung. I already installed all the new construction recessed lights, got nspected, and tested. I notice that in one room (4 cans) one of the lights after a while will shut off for a while, then once off will come back on after a little time. This keeps continuing. It is only the one and the same light everytime. What would cause this? I what to correct the issue before the insulation and ceiling goes up. It is all new 20 amp 12/2 and it is conected to temporary power. What would cause this?
gregt848 is offline   Reply With Quote
Old 05-24-2010, 09:33 AM   #2
Rewards Points: 308
The T-Sat could be bad or the fixture is getting hot for some reason. If there is no obstruction keeping heat in the fixture, replace the fixture. There will be a small button (t-stat) inside the can if the fixtures are "IC" rated. This button is what opens the circuit on over heat. I do not think they are removable, or replaceable. I am fairly certain you will just need to replace the whole thing. "the fixture"
Old 05-24-2010, 04:43 PM   #3
Union Electrician
goose134's Avatar
Try a smaller wattage lamp. Look at the sticker on the inside edge of the can, it will tell you what size you can use with what trim.
goose134 is offline   Reply With Quote
Recessed light tripping GFCI Sayne Electrical 3 05-12-2010 11:57 AM
Recessed light suggestions? vyjeff Electrical 1 04-27-2010 01:26 AM
Recessed Light Placement jonathan03 Electrical 6 04-04-2010 12:33 PM
Recessed light directly over shower adpanko Electrical 33 09-16-2009 06:56 AM
Installing a Fan in a Recessed Light Fixture MMP Electrical 6 06-28-2009 10:41 AM
