Recessed Light --> Ceiling Fan?? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Jim Port
Old 04-11-2017, 07:36 AM   #1
Rewards Points: 16
Recessed light --> Ceiling Fan??
Hi all and thanks for advice...
I have moderate experience with electrical; I know how to add a ceiling fan to preexsisting hole/wiring, or cut a new hole and run new wires to a switch / install new switch etc..
- Im in a nice rental house and have recessed lights.. Please correct me if Im overlooking anything but I believe I can just remove the recessed light bulb, remove the "cup" housing, add in a support bracket for a fan (obtain at home depot), just use those wires to power a fan.. Since I dont want to run new wires to the switch Ill just use that one switch as the "main on and off" switch for both light and fan.... then just use pull chains or a remote to adjust accordingly.
Any thing missed? Any tips or tricks to give me?
THANKS ALL!!
Jondoyle24 is offline   Reply With Quote
Old 04-11-2017, 08:11 AM   #2
Licensed electrician
Rewards Points: 3,740
Re: Recessed light --> Ceiling Fan??
Since this is a rental you have no rights to make any changes. Perhaps you can work out a deal with the landlord.
BluegrassGuy likes this.
Old 04-11-2017, 08:42 AM   #3
Rewards Points: 16
Ahhhh ok thanks
Old 04-11-2017, 04:36 PM   #4
Rewards Points: 312
Originally Posted by jim port View Post
since this is a rental you have no rights to make any changes. Perhaps you can work out a deal with the landlord.
unless its in the lease that changes are allowed, as long as they remain upon vacating. Ive rented placed many years ago that allowed me to make (approved) changes, as long as they remain when i leave.
KPDMinc is offline   Reply With Quote
How to paint ceiling without removing recessed light trims stripedbass Painting 7 08-01-2015 09:25 PM
General question about cost/energy use of additional lightbulbs to a ceiling light popo619 Electrical 15 05-12-2013 09:46 AM
recessed light and drop ceiling BlueBSH Electrical 5 03-08-2013 08:14 PM
Three romex into recessed light box - light won't turn off coopns Electrical 12 05-04-2012 07:27 PM
Trouble Inserting Recessed Light Into Ceiling Cavity PotLightGirl Electrical 7 11-02-2009 01:15 PM
