Recessed Housing Is Labeled IC/Non-IC....... - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2010, 07:00 PM   #1
DYI Novice
Recessed housing is labeled IC/Non-IC.......
What exactly does that mean?? I have 2 of these exact units. How do you install it differently to make it an IC unit??
http://www.thomaslighting.com/catalo...il.asp?cno=PS5
hawks81 is offline   Reply With Quote
Old 07-28-2010, 07:42 PM   #2
Licensed electrician
Rewards Points: 3,660
If these are similar to the Progress brand the unit can be either IC or non-IC based on the trim selected.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
hawks81 (07-29-2010), Proby (07-28-2010)
Old 07-28-2010, 11:24 PM   #3
Electrician
Proby's Avatar
Interesting, I've never seen that before.
Proby is offline   Reply With Quote
Old 07-29-2010, 09:22 AM   #4
gmhammes's Avatar
I have the same ones and actually contacted the company. there is a metal spacing insert within the can that has the fixture mounted to it. With it that way, the unit is IC rated. I opted to removed that metal piece and put a full trim bezel in the can which according to Thomas is also IC rated.
You should be ggod whichever way you go. Just don't move the spacer up as that will make it non IC.
gmhammes is offline   Reply With Quote
The Following User Says Thank You to gmhammes For This Useful Post:
Old 07-29-2010, 02:17 PM   #5
DYI Novice
Could it simply be that the fixture is rated at 55W and therefore going higher than that would require a Non-IC installation?!?!
Old 07-29-2010, 03:08 PM   #6
gmhammes's Avatar
I wouldn't go higher wattage than it's rated either way. The owners manual describes the IC vs non-IC as well
Old 07-29-2010, 03:30 PM   #7
The inside label will tell the correct bulb and combinations that can be used. Some will only be for use in a non-IC type usage. Change the bulb and trim and the same housing can now be used as an IC fixture.
Recessed light suggestions? vyjeff Electrical 1 04-27-2010 01:26 AM
recessed cans ic?? rakuz66 Electrical 5 04-14-2010 03:08 PM
remodel recessed housing proximity to stud DIYGST Electrical 5 01-02-2010 03:40 AM
IC vs. IP recessed housing sastexan Electrical 6 02-26-2008 09:15 PM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
