Recessed Cans / Pot Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2010, 09:44 AM   #1
I had a contractor finish my basement but now it might turn into a DIY - what a nightmare.
Basically he installed some recessed cans but when installing the trim there were tons of gaps/holes as the original hole were not cut right. He's patched those up but now the lights don't even sit flush to the ceiling - is that normal? At times I can't even get the trim back into place.
What are my options to fix this? Any advice is greatly appreciated.
Thanks,
Parv
Recessed Cans / Pot Lights-image005.jpg   Recessed Cans / Pot Lights-image003.jpg   Recessed Cans / Pot Lights-image002.jpg
Parv is offline   Reply With Quote
Old 03-24-2010, 10:55 AM   #2
Master Electrician
Rewards Points: 5,084
Are the cans not fastened?
brric is offline   Reply With Quote
Old 03-24-2010, 11:09 AM   #3
I'm not sure how to check - they seem really loose. Can I still fasten them?
Old 03-24-2010, 11:18 AM   #4
Master Electrician
Was the ceiling open or already covered? If it was already finished and the photo is an idication, that appears to be a new work can as opposed to a remodel can which should have been used in an existing ceiling.
Old 03-24-2010, 11:20 AM   #5
This was a brand new ceiling - it's part of a basement renovation. I think they used the correct lights but just didn't install them properly.
They aren't suppose to look like this right?
Old 03-24-2010, 01:11 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 980
Most cans have an adjusting screw inside to allow you to slide the body up and down.
You may be able to adjust the can flush, but not sure how you can fix the gap.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 03-25-2010, 12:37 AM   #7
Master Electrician
if you look closely at the first picture you can just make out what seems to be the "slide type tabs" consistant with a retrofit can. if the holes where cut right which they aren't then you would just slide those down to "pinch" the fixture between the drywall. Either way though if the cans are lose and they are a new installation fixture or retrofit i hope you didn't pay the contractor because he pulled one over on you. Those lights look like the type you buy at home depot for 50 bucks for 6....in other words they're really cheap.
andrew79 is offline   Reply With Quote
Old 03-26-2010, 02:00 AM   #8
Electrician
Rudeboy's Avatar
Mistakes happen, but no, that is not normal or a quality install. It pisses me off, I can imagine how you feel.
Your first option would be to get the contractor to fix it, and don't pay him a dime before he fixes it. And if you paid him in total, don't pay him anything else after he fixes it.
Rudeboy is offline   Reply With Quote
Need some guidance on recessed cans wiring..... TyWebb Electrical 6 02-17-2010 01:01 PM
Recessed lights, wiring, breaker buzzing, etc diyguy999 Electrical 3 12-21-2009 01:10 PM
installed recessed lights but now switch does not work auggie77 Electrical 2 08-02-2009 10:11 AM
Fluorescent lights to recessed cans. How do I determine where and how many? Bacardi 151 Electrical 13 11-06-2007 01:37 AM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 05:02 PM
