Receptical Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-09-2010, 07:48 PM   #1
Receptical Question
I am possibly getting a 120a Mig from Harbor Freight which requires a NEMA L6-30 or equivalent plug. When I was at Home Depot I seen a L6-30p and a L6-30r. I had also seen a 6-30p and 6-30r, not with the L of course. The L6-30's are rated for 30a/240v and the plain 6-30's are rated for the same except I believe it was 250v. Do I HAVE to install the L or can I install the regular 6-30's?
Now keep in mind I am aware I have to run a 30a 240v fuse and all that, I just need the info about the plug and receptacle. Thanks.
ccross is offline   Reply With Quote
Old 12-09-2010, 07:53 PM   #2
Master Electrician
Rewards Points: 5,082
Your receptacle will need to match the plug on the welder.
brric is online now   Reply With Quote
Old 12-09-2010, 08:03 PM   #3
Rewards Points: 330
L is for locking as in twistlock.
oleguy74 is offline   Reply With Quote
Old 12-09-2010, 08:07 PM   #4
I figured that the L stood for locking, but is it absolutely necessary? The reason why I ask is because normal 6-30's are $10.00 cheaper than the L's.
Old 12-09-2010, 08:09 PM   #5
Rewards Points: 330
saftey issue.don't want it un pluged while you are welding.
Old 12-09-2010, 08:17 PM   #6
Gotcha, thanks!
Old 12-09-2010, 08:29 PM   #7
Master Electrician
If the welder is supplied with an L6-30P YOU WILL NEED AN L6-30R receptacle. An L6-30P will NOT fit a 6-30R receptacle.
Old 12-09-2010, 10:06 PM   #8
Yes, I am aware of this.
Old 12-10-2010, 07:15 AM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
I'd say this is more of a convenience issue than a safety issue.
Old 12-10-2010, 10:40 AM   #10
Rewards Points: 330
the main issue is you dont want the machine to accadently get un pluged.
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
