Receptacles Too Low! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-27-2010, 11:29 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Originally Posted by Smoke View Post
It is down to a science. Receptacles are a certain height off the floor, light switches are a certain height off the floor, RECEPTACLES are a certain height above a vanity (Which are all standard heights ...............
Sorry, you can continue to tell yourself this, but you are 100% WRONG.
There are no "specific" standard heights. There are rules of thumb. There are what many folks do. There are guidelines. But unless you get into ADA specifics there are NO specific height standards/requirements for a small residential job like this.
Old 06-28-2010, 04:03 AM   #17
Rewards Points: 1,192
I think the ADA is distorted.Why have a light switch at 4' to the top,in a mechanical room in case a wheelie comes in?
bobelectric is offline   Reply With Quote
Old 06-28-2010, 06:34 AM   #18
the Musigician
DangerMouse's Avatar
Maybe he just assumed you were planning on tiling the back wall (no backsplash) and had the outlets right where you wanted them?
DM
Old 06-28-2010, 07:32 AM   #19
I=E/R
a7ecorsair's Avatar
It is down to a science. Receptacles are a certain height off the floor, light switches are a certain height off the floor, RECEPTACLES are a certain height above a vanity (Which are all standard heights unless you are a hobbit that lives in the movie "Lord of the Rings" where they are 3 feet tall)
Yes, you are correct. Vanities have a standard height which is 34" to the top of the backsplash from the sub floor, however, it is not uncommon to install a counter height vanity which makes the backsplash 38" above the sub floor.
So, are you installing the vanity on top of the finished floor? Are you installing a standard vanity or a counter height vanity?
a7ecorsair is offline   Reply With Quote
Old 06-28-2010, 09:51 AM   #20
Rewards Points: 308
If I were doing this job for you I would have asked for the height requirement. I disagree with all the pro's on this one. If I am not sure about any part of any project I would ask. I would ask the customer to get me the dimensions of the vanity. Height and width! I would have not installed them without this most critical information.
How could any electrician magically know how high or low to install the receptacles? IMO the electrician while not completely his fault dropped the ball on this and he should come back and get it right.
Did you have the vanity and sink top on the premises when the electrician was there?
Old 06-28-2010, 08:22 PM   #21
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
thats where i mount all my switch boxes
plummen is offline   Reply With Quote
Old 06-28-2010, 10:01 PM   #22
THANK YOU J.V.!!! I was starting to think that I was crazy! What was the sentence you wrote? Oh, it was, "If I was the contractor and I wasn't sure....I would ask"! How bout that boys and girls! And after a little research at the home improvement companies...vanities DO come in standard heights which are 31" and 33 1/2" which if I was a "Professional" I would allow for a counter top with a 3-4" backsplash! No need for the homeowner, "the one who hired the "professional" to do the calculating for me", to measure all of this!!! This is why I hired you! So now, I have resorted to getting a 31" high vanity and a countertop that measures 3 7/8" from bottom to top to just slide in under the electrical faceplate that measures 35" from the bottom of the faceplate to the TFF! I am not holding back this guy's money but I feel that I have let him off the hook!
Smoke is offline   Reply With Quote
Old 06-28-2010, 10:35 PM   #23
plummen's Avatar
i ask again did you walk through the bathroom at anytime during the construction process before the drywall was hung?
maybe you could post the electricians number so we can get his side of what happened throughout the process since you seem to be so determined to blame him for the problem
Old 06-28-2010, 10:39 PM   #24
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
If you look here you will see that the actual cab height is 29 1/2":
http://www.midamericacabinets.com/ca..._lavatory.html
Ok, you have 37" to center. A trim plate is 2 3/4" so half of that is 1 3/8". That means as long as your splash is below 35 5/8 you are fine. A lav base varies but the intent is to allow the counter top to be at ~30". As you can see above, their lav cabinets are 29 1/2". That is to allow for 1- 1 1/2" for the countertop itself. Let's go with 1 1/2" so now we are at 31". Add a 4" splash and you are at 35". Since the trim plate will be at 35 5/8", I'm just not seeing a problem here. You have 5/8" to spare.
So, what is the problem?
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Rewiring - adding receptacles, paths to use RST Electrical 2 03-14-2010 02:29 PM
Maximum number of receptacles on 15 amp circuit flati Electrical 11 03-07-2010 08:08 AM
GFCI between porch receptacles Thurman Electrical 4 08-19-2009 12:40 PM
receptacles have no power, im at a loss reds_21 Electrical 3 10-05-2008 10:49 AM
