Receptacles - Max Allowed On Circuit ? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-17-2010, 08:42 PM   #1
Question
Receptacles - Max allowed on circuit ?
how many recepticles can you run off of one 15 amp breaker and be on the safe side
BSGSLIM is offline   Reply With Quote
Old 03-17-2010, 08:45 PM   #2
Electrician
Rewards Points: 910
In the US if it is a general use receiptical there is no limit, i wouldn't put more then 8 to 10 on it if it were me.
In Canada the limit is 12 outlets on a circuit.
Please update your profile to indicate your location and we can answer your questions easier in the future.
darren is offline   Reply With Quote
Old 03-17-2010, 08:46 PM   #3
Where are you located ?
In the US there isn't a limit
You try to plan the outlets based on anticipated loads
Its the loads that restrict you....not the number of receptacles
Old 03-17-2010, 08:58 PM   #4
i appreciate your help in some rooms im doing i have only needed 5 and some rooms need more but i wasnt going to go over 7 on one breaker.i recently had a house fire so i have decided to rewire the whole house since it was because of old wiring. i will update my profile so u all will know what city and state i live in.
Old 03-17-2010, 09:00 PM   #5
i am in the us i live in virginia
Old 03-17-2010, 09:09 PM   #6
What rooms are you rewiring ?
Bathrooms require a dedicated 20a circuit can include lights
OR all bathrooms can share a 20a circuit that is outlets only
Bedrooms & most other areas require AFCI breakers now
I run a 20a circuit to each bathroom
Laundry area requires a dedicated 20a circuit
I run a dedicated 20a circuit to TV room
Have you checked with the Building Dept to see what they want as far as Inspections ?
Old 03-17-2010, 10:16 PM   #7
" Euro " electrician
frenchelectrican's Avatar
Basically in USA there is no limit on resdentail side for the number of recetpatles.
However., as ScubaDave highlighted there are couple rooms / area it will have restrictions like bathroom it will have it own circuit or two bathrooms with recetpales only.
Garage useally on it own circuit { it will be 20 amp with GFCI protection btw 2008 NEC codes there is no extempts on them anymore unless your local codes may override it }
Merci.Marc
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 05:00 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 10:31 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
