Receptacle Wiring With 14 And 12 Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 05-18-2013, 07:34 AM   #1
Receptacle Wiring with 14 and 12 wire
I have a receptacle that has three cables coming into the box, 2 cables are 12/2 and one is 14/2. Someone wired it putting two wires under one screw and one wire under another on each side of the receptacle.
To correct this, should I just connect the two 12 wires and pigtail the 12 to one screw and put the 14 wire on the other screw?
diverdave is offline   Reply With Quote
Old 05-18-2013, 07:39 AM   #2
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
which one is the feed ?
what is the breaker size ?? of that circuit ??
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-18-2013, 08:46 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Just use one pigtail, #14 is fine. MAKE SURE the breaker is 15A.
Whoever put #14 on that circuit limited the whole circuit to a 15A breaker.
Old 05-18-2013, 09:00 AM   #4
Are you saying use 14 wire as the pigtail off of the two 12 wires? I guess using 14 as the pigtail is ok since that circuit should be limited to a 15 amp breaker.
Yes I am aware that there may be an issue with the size of the breakers. I am pretty sure that there are some 20 amp circuits that have 14 wire on them. Next week I have an electrician coming to check my panel to make sure the fuses are correct at the panel.
Is there an easy way to check for 14 wire that may have been added later on a 20 amp circuit or do you just have to check every receptacle, switch, etc?
Old 05-18-2013, 09:31 AM   #5
Electrical Enthusiast
Rewards Points: 504
You would have to (at least) take the face plates off of every switch and outlet in order to check. You also may want to look in the attic or crawl space for "flying splices."
Kyle_in_rure is offline   Reply With Quote
Old 05-18-2013, 09:33 AM   #6
Yes.
Unfortunately no.
wiring a whirlpool cooktop davidtyson Electrical 8 06-17-2012 01:58 AM
Wiring receptacle > switch > motion sensor lights Van Home Electrical 11 08-09-2010 11:27 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
Wiring a 220v dryer receptacle pjpjpjpj Electrical 8 06-05-2007 04:08 PM
