Receptacle Controlled By Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 07-15-2010, 06:49 PM   #1
receptacle controlled by switch
how to wire my recessed lighting?
where do i connect my recessed lighting on the receptable or switch
thanks
jp
dp12345 is offline   Reply With Quote
Old 07-16-2010, 10:06 AM   #2
Licensed electrician
Rewards Points: 3,654
I am going to make the suggestion that you pickup a copy of "Wiring Simplified" so you can have a better idea of the general concept and methodologies of wiring simple projects.
Old 07-16-2010, 12:02 PM   #3
I would agree with Jim. It sounds like you either need to do a more thorough job of describing what you are doing and what you want or learn the basics of what you want to do and then come back with any further questions or to validate what you understand.
Browse the forums for the types of questions that people can answer. Unfortuneatly the question you asked is so general that entire books have been written on it.
Troglodyte is offline   Reply With Quote
Outlet controlled by light switch billvasko Electrical 3 12-29-2009 05:57 PM
Switch now controls large area... froddan Electrical 5 12-06-2009 10:04 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
switch controlled recptical handifoot Electrical 3 03-01-2009 12:53 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
