Range Wiring - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 07-24-2019, 08:36 AM   #1
Range Wiring
I'm getting new cabinets in an old kitchen and I needed to move the outlet for the range. There are only 3 wires (black, red and bare ground wire) but the outlet is a four prong outlet. What do I do with that ground wire? Does it serve as the neutral? I don't remember how it was hooked up when I removed it.
Cball is offline   Reply With Quote
Old 07-24-2019, 08:47 AM   #2
Rewards Points: 58
The old range used the same wire for neutral and ground. Now days a separate wire is required .
Wiredindallas is offline   Reply With Quote
Old 07-24-2019, 08:59 AM   #3
Re: Range Wiring
So do I connect the bare ground wire to the neutral terminal and leave the ground terminal empty?
Old 07-24-2019, 09:06 AM   #4
retired framer
Rewards Points: 8,648
Re: Range Wiring
Same range or new one?
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 07-24-2019, 09:16 AM   #5
Re: Range Wiring
New range. Actually, we have a gas range but I wanted the wiring in place in case next owner wanted electric.
Old 07-24-2019, 09:20 AM   #6
Super Moderator
joed's Avatar
Rewards Points: 30,888
Re: Range Wiring
Put in a three prong range receptacle or pull a new four wire cable if you want the four prong receptacle.
Old 07-24-2019, 09:31 AM   #7
retired framer
Re: Range Wiring
I would pull the breakers for the stove cap the wires on both ends and put a blank on the box behind the stove, and let the next guy deal with it. You can't help him by breaking the rules.
CodeMatters likes this.
Old 07-24-2019, 10:18 AM   #8
Re: Range Wiring
Thanks to all of you for your help. One more question and I'll quit. I could possibly fish a ground wire to this outlet- does it need to be the same gauge as the hot and neutral wires?
Old 07-24-2019, 10:24 AM   #9
Super Moderator
joed's Avatar
Re: Range Wiring
You already have a bare ground. You are not permitted to fish a neutral, which is what you need.
If you can fish a ground then fish then whole new four wire cable.
Old 07-24-2019, 05:08 PM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 328
Re: Range Wiring
2 insulated conductors and a bare ground was never a compliant 3 wire range circuit.
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
