Range Outlet Required? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-21-2009, 02:49 PM   #1
Range outlet required?
I pulled out my old drop-in electric range (from around 1985) to prepare for the delivery of my new freestanding, double oven electric range.
The old range was hardwired in. I consulted the pdf manual of the new range online and it looks to have the option of installing hardwired or with a plug.
Does current code require a plug & outlet or can I hardwire (I live in Virginia)? Is there any other benefit of going the extra step to put in a plug?
Thanks.
A for Effort is offline   Reply With Quote
Old 07-21-2009, 02:58 PM   #2
300zx's Avatar
Thanks.
What size(Wire and Amps,volts) was the old drop in electric range .And what is the name plate say on the new one for amp, volts .Need a little bit more info thanks
300zx is offline   Reply With Quote
Old 07-21-2009, 03:07 PM   #3
The old range is a 3 wire, 240 V. The breaker has a 50 A fuse for the range.
The specs for the new range (copy and pasted from the pdf):
This range requires a single phase three wire
120/240 or a 120/208 volt, 60 Hz, AC circuit.
When using a power supply cord, use only a supply cord
with closed loop terminals rated either 240 volts, 40 amps or 240 volts,
50 amps that is marked for use with nominal 1-3/8 (34.94 mm)
diameter connection opening and marked for ranges. A 4-conductor
cord is to be used on new branch-circuit installations (1996 NEC),
mobile homes, recreational vehicles and where local codes prohibit
grounding through the neutral conductor. A 3-wire service may be used
when permitted by local codes.
Old 07-21-2009, 03:25 PM   #4
Remodeler
adpanko's Avatar
Rewards Points: 150
So you need a 50A circuit for the new oven. That requires 6/3 wire. Check to see if the existing wiring is 6 guage. If it is, you're fine. If it is 8 or 10 guage, you should repull new 6/3 wire.
You should just hardwire it. For a built in double oven unit like yours, I don't really see a benefit to having an outlet/plug. I'm fairly certain code doesn't require a plug for a built-in unit like that. My father had a double oven Dacor unit installed, and it was hardwired by the installer; no outlet. Save yourself the step of putting in an outlet. That thick gauge wire is hard to work with, and trying to make a connection to an outlet and get the wire pushed back neatly into the box so the outlet can be screwed on is a real hassle.
adpanko is offline   Reply With Quote
Old 07-21-2009, 04:48 PM   #5
Electrical Contractor
kbsparky's Avatar
You can hardwire the new appliance if desired. This is one reason why new appliances do not come with cords.
-KB
Old 07-21-2009, 05:30 PM   #6
Thanks for the feedback! I was hoping to eliminate the extra step of putting the outlet...just wanted to make sure I wasn't going to burn my house down by overloading
I think it would be silly for code to require an outlet for a range like this that has no drawer and the only way to unplug it would be to pull the whole thing out.
Thanks again for the input!
Old 07-21-2009, 07:15 PM   #7
Not necessarily.
Existing circuit is likely #8 SE
Some local codes require pigtail/plug but I would just hardwire it.
220/221 is offline   Reply With Quote
Replace Range Outlet Suncrest79 Electrical 22 04-14-2009 11:32 PM
Dryer outlet vs. Range outlet cindakay Electrical 24 04-13-2009 06:01 PM
Range outlet pushes oven too far from wall givemeabreak Electrical 8 08-19-2008 12:14 AM
changing a range outlet or plug marty7 Electrical 9 12-17-2007 10:11 PM
Range outlet required? Doug_Shaver Electrical 2 06-12-2007 05:10 PM
