Questions About Replacing My FPE Panel - Electrical - Page 7 - DIY Chatroom Home Improvement Forum
Old 04-24-2014, 09:24 AM   #91
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,132
Originally Posted by rjniles View Post
As jbfan said most cables do not have the individual conductors identified. I have never seen SE so marked.
Install a larger LB and bush it down to 2".
Originally Posted by HouseHelper View Post
Yes, it's called a 2.5" LB.
Yep.... obvious good/only solution for me...
(Wonder if that instance that BO advised/approved had labelled conductors??)
Thanks..... I thought it was just me that couldn't get that fat girl in a girdle )
MTN REMODEL LLC is offline   Reply With Quote
Old 04-24-2014, 11:47 AM   #92
Finch1985's Avatar
Rewards Points: 79
How come my new Siemens panel doesn't have big enough openings in the neutral bar for my 3 wire circuit neutrals like my range, dryer, and heat pump? The FPE has several slots big enough to support these bigger wires. Da hell?
Sent from my SCH-I545 using Tapatalk
Finch1985 is offline   Reply With Quote
Old 04-24-2014, 12:12 PM   #93
Master Electrician
Rewards Points: 5,252
The Siemens equipment I am familiar with have lugs large enough for # 4 conductors. Add- on lugs are available for larger conductors.
brric is offline   Reply With Quote
Old 04-24-2014, 12:18 PM   #94
Master Electrician
[ATTACH]http://www.ecmag.com/section/systems/conductors-connected-parallel[/ATTACH]
Old 04-24-2014, 12:20 PM   #95
Master Electrician
Deleted
Old 05-08-2014, 07:27 AM   #96
Finch1985's Avatar
Rewards Points: 79
Well tomorrow is the big day. An electrician has agreed to help me get the new panel installed and the service conductors installed and I'll take over from there. So he's going to be saving me some money and I get to do most of the work myself which I find enjoyable.
Started prepping last night.
The Following User Says Thank You to Finch1985 For This Useful Post:
jbfan (05-08-2014)
Old 05-08-2014, 03:27 PM   #97
Where are all your sticky/post-it notes.....
Old 05-08-2014, 03:30 PM   #98
Finch1985's Avatar
Rewards Points: 79
well, I'm gonna label tonight.
Old 05-08-2014, 05:19 PM   #99
deverson's Avatar
Rewards Points: 77
Looks like a lot of housekeeping needs to be done. Lots of stapling is missing. KO's hanging out the bottom. Tough to get a romex connector with the slugs still in place. Not sure if the is a ground wire there or not. Just to mention a few items to address.
deverson is offline   Reply With Quote
Old 05-08-2014, 05:21 PM   #100
Finch1985's Avatar
Rewards Points: 79
Does it need to be stapled if the wall will be covered? This is the existing panel btw.
Old 05-08-2014, 05:27 PM   #101
deverson's Avatar
Rewards Points: 77
Yes, you have to staple even if you cover the wall. Right now the wall is open.
Sub Panel Questions jeff987654321 Electrical 22 10-24-2011 07:11 AM
Questions on replacing central air Klawman HVAC 20 08-20-2011 09:27 PM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Replacing a 100A panel The Woot Electrical 5 10-30-2008 12:40 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
