Questions About Materials/how. RE: 220v Line - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 05-12-2010, 03:48 PM   #1
Questions about materials/how. RE: 220v line
I'm in a rental and don't want to install a new breaker. I also don't want to because it may be too much for me. I was talking to a Home Depot employee and he told me I could piggyback off the existing 220 line for my dryer, at the breaker. He emphasizes that I would NOT be able to use both lines. I completely understand that and am installing a timer for the dryer. This way, the hours I will be using my other equipment, the dryer won't work. Just in case the wife forgets.
So, first question: If I can piggyback off the existing breaker, can I just piggy back off the dryer outlet itself? This way, it will be easier to install the dryer timer, and I can use less wire overall. Also, I don't have to open the breaker box if I don't have to. Other than to turn the power off.
2nd: Would I use a box like this large enough to house both outlets?
amarillo is offline
Old 05-12-2010, 04:34 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
You cannot do this. Among other things, a dryer line is on a 30A circuit and you CANNOT have standard 15 or 20 amp devices on a 30A circuit.
Speedy Petey is offline
Old 05-12-2010, 04:36 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 23,978
It's a rental you are not permitted to do any work without landlord permission. It also must be done by licensed electrician.
joed is offline
Old 05-12-2010, 04:43 PM   #4
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
I would have to agree with both of the above posts!
Answers based on the mood I am in when you ask!
sparks1up is offline
Old 05-12-2010, 05:08 PM   #5
Home Depot employee is completey wrong as USUAL
What you are trying to do is completely wrong
You are a renter & if you burn the place down will be liable for all damages
Do not touch the electric system, call your landlord
Scuba_Dave is offline
Old 05-12-2010, 05:19 PM   #6
Master Electrician
Rewards Points: 5,082
I'd be curious as to what exactly you are trying to do. Those are 120 volt receps in the photo not 240 volt.
brric is offline
Old 05-12-2010, 05:40 PM   #7
No, No, I am not gonna use 120v receptacles, I will be using 220v receptacles. I only showed those as an example of the metal "box" I thought I would have to use. I couldn't immediately find the exact one I needed.
I've already talked to my landlord about having someone out to add the line, and it's okay. I would just like to save myself a couple hundred bucks if I could. Considering it isn't my home, I'd like to avoid investing that much.
I also "will" be using 220v equipment.
amarillo is offline
Old 05-12-2010, 05:47 PM   #8
Its not your home so no you are not allowed to do the work
You need to hire someone
Old 05-12-2010, 05:48 PM   #9
I got that. Am I not allowed to ask because it isn't my home? That would make this very clear. Cause, i already understand that it isn't my home.
amarillo is offline
Old 05-12-2010, 06:11 PM   #10
Your landlord has stated that you can hire someone
-closed-
Closed Thread
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 04:13 PM
Do I need to prime my oil feed line? 1parkpointer HVAC 3 10-22-2009 06:52 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 07:51 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 08:19 PM
