Question About Using Resistors - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-12-2014, 09:10 PM   #16
Why not just go to radio shack and grab a couple of the 5 volt regulators for something like $1.00 each.. That drops your 12v down to a regulated 5v.. then hook up a series resistor in front of each bulb as a current limiter.. One regulator is good for 1amp so you should be able to power several bulbs under each regulator.
Now, when your 12 volt battery drops in voltage, the regulator will still put out a steady 5 volts.. Also, when one bulb goes bad, nothing changes.
Cheap and simple..
PaulBob is offline   Reply With Quote
The Following User Says Thank You to PaulBob For This Useful Post:
dmclean701 (08-13-2014)
Old 08-13-2014, 07:33 AM   #17
Super Moderator
joed's Avatar
Rewards Points: 30,966
They do make 12 volt version of the bulbs.
Tags
12v , hobby , resistors
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
