Question About Running NM And BX In Joists - Electrical - DIY Chatroom Home Improvement Forum
Old 06-14-2010, 02:27 PM   #1
Question about running NM and BX in joists
I have an unfinished ceiling in my basement that I am currently prepping for a Ceiling Max type ceiling. I have a run of old woven jacket wiring that goes from the breaker box to the kitchen, but is stapled underneath the joists. I also have a run of BX that follows the same path, but is run perpendicular through the middle of the joists. I am planning on replacing the old woven jacket wiring with NM, but would like to run this through the bored holes that the BX currently goes through. Is it a code violation to run a NM cable and BX cable through the same hole(s) in joists?
Thanks in advance, I really appreciate it.
stock2mal is offline   Reply With Quote
Old 06-14-2010, 02:45 PM   #2
Master Electrician
Rewards Points: 5,082
No issue as long as the holes are large enough. Be careful not to damage the new NM pulling next to the BX.
brric is offline   Reply With Quote
Cut Joists - How to Repair? stubits Building & Construction 13 03-16-2010 05:12 PM
Making a floor in a garage. What size floor joists? GD73 Building & Construction 2 07-19-2009 06:07 PM
wire running question ponch37300 Electrical 4 04-21-2009 03:58 PM
help with 2nd floor joists g heil Building & Construction 5 09-12-2008 06:41 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
