Question About Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2010, 10:45 AM   #1
question about outlets
Wanting to install 6---15 amp outlets and am wondering if there is a type of outlet that allows you to simply push in the wires as oppossed to the use of the screws.
raineydr is offline   Reply With Quote
Old 03-15-2010, 10:52 AM   #2
Just call me Andrew
Rewards Points: 1,032
Go for "back-wire" outlets. You slide the wire under a clamp, then tighten the screw. Much easier than wrapping the wire around the screw, and secure.
You are describing a "back-stab" connection, where you simply push the wire in and it "locks" into place. These outlets are not reliable and tend to get loose over time.
Andrew
secutanudu is offline   Reply With Quote
Old 03-15-2010, 11:03 AM   #3
Thanks for the info. Is 6 the limit for the number of 15 amp outlets I can wire one 15 amp circuit.
Old 03-15-2010, 11:05 AM   #4
Just call me Andrew
That depends...where are you located?
There is no limit in the US. You can install as many as you want. It depends what you will be plugging into them. Is this a new circuit? If so, I'd recommend using 12/2 wire and a 20-amp breaker for outlets.
Andrew
Old 03-15-2010, 11:12 AM   #5
I am in th U.S. I have 1 designated for a flat screen tv and a dvd player; 1 designated for an air hockey table; and the others for small stuff like lamps. So I can actually run 15 amp outlets with 12/2 wire on a 20 amp circuit?
Old 03-15-2010, 11:14 AM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 946
yes you can.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 03-15-2010, 11:27 AM   #7
Just call me Andrew
If all the wiring is 12/2, you can always up to a 20-amp breaker if you find that the breaker is tripping.
Andrew
Old 03-15-2010, 11:34 AM   #8
I would not use the push in type outlets
They are fairly cheap & there have been problems in the past with them
There are outlets that you insert the wire & then screw down a plate to clamp down the wire - as secutanudu stated
Old 03-15-2010, 11:34 AM   #9
Just call me Andrew
If you're hanging your tv on the wall, might want to consider one of these surge protection outlets.
http://www.amazon.com/Leviton-ACSSR-.../dp/B001U3Z484
Andrew
Old 03-15-2010, 07:07 PM   #10
jbfan's Avatar
Rewards Points: 946
Back stab receptacles will no longer accept #12, only #14.
Old 03-15-2010, 07:19 PM   #11
Rewards Points: 1,016
If you pig-tail the outlets, then you can attach the pig-tails to the screws of the outlets while sitting in a comfy chair and were they are easy to do - then just wire nut in the pig-tails.
Old 03-15-2010, 08:07 PM   #12
firehawkmph's Avatar
Rewards Points: 2,474
Ditto on what vsheetz said. What the hecks so hard about wrapping a wire around a screw and tightening the screw anyway?
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-15-2010, 08:46 PM   #13
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
If the wiring is all #12 DO NOT bother with a 15A breaker. Just install a 20A and be done with it.
Old 03-15-2010, 09:18 PM   #14
Just call me Andrew
Good call.
Andrew
GFCI question. Please Help. the banana k1ng Electrical 4 10-09-2009 07:35 PM
Power leading to outlets but no power ? s_anthony Electrical 22 01-05-2009 01:08 PM
downstream of GFCI outlets amakarevic Electrical 11 12-25-2008 01:13 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 05:44 AM
