Question About Neutral Wire Through Wall Switch - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-08-2010, 06:52 PM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 944
You are missing a pair of wires.
If you only have 2 wires at the light, and 2 at the switch, the light would not work.
You must have another set of wires for the power from the panel.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 08-08-2010, 06:53 PM   #17
If I were to run all new wiring, would this diagram (see attachment) be correct? This diagram is basically if I were to run a complete new line, discarding all the old wiring.
guitarmonster is offline   Reply With Quote
Old 08-08-2010, 06:55 PM   #18
Electrician
Proby's Avatar
Yes, that's exactly it.
I am assuming you have a hidden junction box somewhere, that is why you only have two wires in each box.
The light box is mounted in the suspended ceiling or the solid ceiling above it?
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-08-2010, 06:56 PM   #19
I know, the light does work, actually it's on right now. For that reason that's what made me think that the line is running from the basement up the wall, then just the hot wire is run into the box to the switch, and then from there both the neutral and hot run up the wall to the light. Basically the same as the diagram I posted (except I don't think a ground wire is present)
Old 08-08-2010, 06:59 PM   #20
Electrician
Proby's Avatar
Yeah, maybe it's old knob and tube.
You are still better off running a new feed up to the switchbox and then running a new cable up to the light box.
Since you have a suspended ceiling, it will be very easy to get a wire into the ceiling by breaking open the wall at the very top (above the suspended ceiling) and then another hole in the ceiling next to it.
Old 08-08-2010, 07:03 PM   #21
Ok cool. Yeah I got real lucky with the suspended ceiling and basement, it's real easy to run wires. So I will run a line consisting of ground, hot, and neutral from the basement up the wall, run all three wires through the box, then out of the box up the wall across the ceiling to the fixture, basically running one wire and cutting into the hot (for the switch), and cutting into the neutral (to power the advanced Insteon switch), and of course the ground attaching to the box itself, and connected to the ground on the switch?
Old 08-08-2010, 07:05 PM   #22
Electrician
Proby's Avatar
Exactly.
Old 08-08-2010, 07:08 PM   #23
Alright, i'm guessing I should use 14-2 wire?
Old 08-08-2010, 07:09 PM   #24
Electrician
Proby's Avatar
Where are you getting the feed from? If you are going to make this a dedicated circuit from the panel, then just make it a 15A circuit and use 14-2. If you are going to splice into an existing junction box, you need to size the wire to that circuit.
Old 08-08-2010, 07:11 PM   #25
Im going to run it off of a nearby outlet, which was recently installed by an electrician so it's new. It's on its own circuit which currently consists of just 2 outlets.
Old 08-08-2010, 07:15 PM   #26
good advice, I just went into the basement and read the wire. It's Romex 12 AWG rated up to 600 volts, connected to a 20 amp breaker.
Old 08-08-2010, 07:16 PM   #27
jbfan's Avatar
Rewards Points: 944
What size is the fuse or breaker?
If 15 amp, then you can use #14.
Old 08-08-2010, 07:18 PM   #28
20 Amp breaker, the circuit is current using 12 awg
Old 08-08-2010, 08:08 PM   #29
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I think all your questions have been answered so here is a diagram of your previous line drawing. I'm not sure which of the two receptacles your wiring the extension from but you get the idea.
I'm showing pigtails at the receptacle you do not have to use pigtails you can just connect to the unoccupied screws with your extension for the light.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 08-08-2010, 08:14 PM   #30
Ok I just want to be sure on one more thing. When I look at this Insteon wiring diagram, I see wires coming into the bottom of the junction box (assuming it's from the circuit box) and wires going out of the top of the box (assuming that goes to the light). It looks like based on this picture the LINE goes to the light, and the LOAD comes from the box, is that correct?
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 01:55 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
