Question About Generator Hookup!! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 07-18-2019, 08:07 AM   #16
Rewards Points: 60
Re: Question about generator hookup!!
Chandler48, thanks for your reply. My generator will supply constant 5500 watts with a starting 6875 surge. I have lp gas with city water so no water pump. I can run water heater by itself, or window unit with central air unit fan to circulate through house. I can run fan for lp furnace along with most lights and refrigerator. Yes I have to turn off and on some breakers but overall this works really well. I already had the wire, hookup inlet and 30 amp breaker. This was the cheapest route and still meet codes and be safe for me.
mattinky is offline   Reply With Quote
Old 07-18-2019, 11:03 AM   #17
Oso954's Avatar
Rewards Points: 1,362
and a 30 amp power inlet installed in my detached garage.
The inlet (and generator) should be on the outside of the garage.
From the manual
Never operate in an enclosed area or indoors! NEVER use in the home, in a vehicle, or in partly enclosed areas such as garages, even if doors and windows are open! ONLY use outdoors and far from open windows, doors, vents, and in an area that will not accumulate deadly exhaust.
Oso954 is online now   Reply With Quote
Old 07-18-2019, 11:28 AM   #18
Rewards Points: 60
Yes I took the reliance 30 amp inlet box down in garage and am in process of installing on outside wall close to the main house panel. I will resuse the 10/3 wire. I have a 30' outdoor generator cable to run generator behind house for noise levels.
I did have the inlet box installed in garage but used my heavy duty 30' cord through window that I purchased on amazon to run generator outdoors.
I would never use generator indoors...thanks for all great tips.
Old 07-24-2019, 08:04 AM   #19
Rewards Points: 60
One last post with pictures...
Finally finished this project....just thought I would post finished pics...thanks for all your help and advice on here...
Old 07-24-2019, 05:39 PM   #20
Naildriver
chandler48's Avatar
Rewards Points: 1,980
It appears your interlock is not requiring you to turn off the generator power when you turn the main back on. Maybe I'm not seeing it all.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 07-24-2019, 06:11 PM   #21
Rewards Points: 1,890
To turn the main back on, you must first slide the bare metal plate to the right. That in turn forces you to turn off the breaker at the top of the right side column, which would be the back feed from the generator.
RAL238 is online now   Reply With Quote
Old 07-24-2019, 06:24 PM   #22
Naildriver
chandler48's Avatar
I see the slide action required, now. Thanks RAL238. I was looking for a vertical movement when the main was turned on.
Larry......
Old 07-24-2019, 06:41 PM   #23
Super Moderator
joed's Avatar
Rewards Points: 31,014
Fooled me as well. I thought the slide action was up/down until I looked closer and saw it was sideways.
BTW those are not legal in Ontario. The presumption is that if the cover is off the interlock is not in effect. It needs to be 100% foolproof.
Old 07-24-2019, 06:56 PM   #24
Rewards Points: 60
It works as is made for, there is no physical way to have both breakers on at same time. Nothing is fool proof If someone removes panel front, most people don’t even bother with any safety features. It’s safe and meets requirements in my area. I’m very pleased with, obviously some people always make negative comments.
Old 07-24-2019, 07:15 PM   #25
Super Moderator
joed's Avatar
Not being negative. I have nothing against interlocks. Just pointing out that in Ontario they are not legal.
Old 07-29-2019, 11:47 AM   #26
Rewards Points: 8,760
Just reading through Matt's multiple threads on generators and want to add I don't believe they are legal here in Maine. It was 20 years ago when I inquired but answer was NO.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
