Question About Amps In Parallel And Series - Electrical - DIY Chatroom Home Improvement Forum
Old 12-24-2014, 06:07 AM   #1
Rewards Points: 4
question about amps in parallel and series
Ok just a little noobie question.
Q1. If I have say 2 batteries both having a max continues draw of 30amps and both are 4.2v. If I put them in parallel would the amps be 60 continues at 4.2v or would it stay the same 30 amps at 4.2v?
Q2. If I did it in series would it be 30amps at 8.4v or 60amps at 8.4v?
Thanks for the help in advance.
xxrampownagexx
xxrampownagexx is offline   Reply With Quote
Old 12-24-2014, 06:37 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Parallel would double the amperage but not the voltage.
Series will double the voltage but not the amperage.
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
jbfan (12-24-2014), mpoulton (12-27-2014), xxrampownagexx (12-28-2014)
Old 12-24-2014, 01:50 PM   #3
Oso954's Avatar
Rewards Points: 1,872
I believe that the 4.2 volts you quoted is the fully charged voltage, not the nominal voltage. If your battery is what I think it is (LiMn), the nominal voltage is 3.7 volts.
The 30 amps continuous is the maximum safe discharge rate for the battery. If you exceed that, it would damage the battery.
Your actual discharge rate is based on the device used. While putting 2 in parallel will increase the safe rate, if you are powering the same device that you did with one battery, it will not increase the actual discharge rate, it just doubles the run time. It is not going to "supercharge" the device.
Oso954 is offline   Reply With Quote
The Following 2 Users Say Thank You to Oso954 For This Useful Post:
Old 12-28-2014, 12:56 AM   #4
Rewards Points: 4
Thanks guys just doing some double checking
parallel vs in series Kelly Durfey Electrical 6 12-22-2012 05:52 PM
Adding 2 outlets in the middle of a series of outlets - wiring question Evan55 Electrical 7 06-14-2012 09:43 AM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
parallel / series wiring question geetee Electrical 5 06-11-2008 02:42 PM
