Question About 220V Breaker For Outside Circuit - Electrical - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 1 Post By chandler48
  • 1 Post By rjniles
  • 1 Post By LawnGuyLandSparky
  • 3 Post By rjniles
Old 04-24-2019, 12:11 AM   #1
Rewards Points: 68
Hello,
I am having a 220V circuit installed in my yard (for a pump) and I have a question about the required breaker(s). The pump contractor who installed the 4" x 4" post with sub-panel in my yard has indicated it will require 220V service using 10-3 direct burial (UF).
Once I go out and get quotes from the different electricians to install the 220V service, I'm wondering if a GFCI breaker required in the electrical panel in the basement? Or whether one is needed in the sub panel?
Basically I want to make sure that when I get my quotes, that each of the electricians are quoting apples to apples 'and' that it is done properly.
Thanks in advance!
Question About 220V Breaker For Outside Circuit-electrical-panel-question-220v.jpg
gil_happy is offline   Reply With Quote
Old 04-24-2019, 12:44 AM   #2
Rewards Points: 680
Re: Question About 220V Breaker For Outside Circuit
Code wise, the GFCI protection is for the load so, it can go in the new panel or the original panel. It's usually more convenient to have it closest to the load. But a contractor may get the idea to GFCI the whole run from the original panel so they don't have to dig the cable as deep.
You might want to get the estimates for both scenarios.
LawnGuyLandSparky is offline   Reply With Quote
Old 04-24-2019, 06:03 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 914
What is the amperage draw of the pump, and will it be the only thing on the sub panel? The term "sub panel" indicates to me additional breaker capability. As mentioned the GFCI will be required, and it can be at either location. I would have opted for a GFCI breaker in the original panel protecting the entire run, with just a disconnect at the post. In addition, if it is truly a sub panel it will need a separate grounding rod. Pictures will help.
mpoulton likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 04-24-2019, 06:54 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 210
If the pump contractor is correct about requiring 10/3 UF cable you need a 2 pole 30 amp breaker in the main panel. Post the specs for the pump. Unless something in addition to the pump will be fed from this sub, you do not need a sub panel but merely a disconnect.
Sub panel feeds do not require GFCI protection. 240 volt circuits do not require GFCI either.
Sent from my RCT6213W22 using Tapatalk
jhil likes this.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 04-24-2019, 08:09 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 210
Deleted double post
Old 04-24-2019, 08:21 AM   #6
wNCmountainCabin
NCmountainCabin's Avatar
Rewards Points: 230
yep, same scenario for RV 50amp power service, which is 240v, with a double-pole breaker at the power pole - no GFCI needed...standard for Campgrounds and RV Parks.
NCmountainCabin is online now   Reply With Quote
Old 04-24-2019, 10:38 AM   #7
Rewards Points: 68
LawnGuyLandSparky - thank you for this. It sounds like from others, a GFCI is not needed for a 240V circuit.
chandler48 - I think I may have misspoken... I think at the post it might be just a disconnect. As far as the draw of the pump, I'm not sure, but the pump contractor certainly knows this info.
rjniles - Thank you for the info. Unfortunately I believe I have misspoken - I think it is a disconnect at the pole.
NCmountainCabin - Great, thanks so much.
Old 04-24-2019, 12:08 PM   #8
Rewards Points: 680
Yup, I stand corrected. I thought your post said a GFCI breaker was needed, didn't realize it was assumed.
gil_happy likes this.
Old 04-24-2019, 05:19 PM   #9
Naildriver
chandler48's Avatar
Rewards Points: 914
The reason I mentioned GFCI protection is because we don't know what type pump he is powering. Is it a Hot tub pump, well pump, or effluent pump.
lenaitch likes this.
Larry......
Old 04-26-2019, 04:47 PM   #10
Rewards Points: 68
My apologies... it is a grinder pump (for my new sewer connection to the city).
Thx
Old 04-26-2019, 04:51 PM   #11
A "Handy Husband"
rjniles's Avatar
Rewards Points: 210
Thx
No GFCI required.
mpoulton, chandler48 and gil_happy like this.
The Following User Says Thank You to rjniles For This Useful Post:
gil_happy (04-26-2019)
Circuit Breaker Question Homey-Homeowner General DIY Discussions 2 05-05-2018 02:00 PM
Circuit Breaker Question Rik R. Electrical 3 02-23-2014 05:38 PM
Dimming lights on one circuit, GFCI breaker tripped boatman537 Electrical 4 06-05-2012 11:43 AM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 04:09 PM
New homeowner here...circuit breaker question fenway71 Electrical 7 01-18-2006 09:39 PM
